Ana içeriğe geç
Shark Flex DuoClean Brush Roll Replacement
  1. Shark Flex DuoClean Brush Roll Replacement, Garage Door: adım 1, 2 resimden 1. Shark Flex DuoClean Brush Roll Replacement, Garage Door: adım 1, 2 resimden 2.
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Shark Flex DuoClean Brush Roll Replacement, Soft Roller: adım 2, 2 resimden 1. Shark Flex DuoClean Brush Roll Replacement, Soft Roller: adım 2, 2 resimden 2.
    • Use the tab on the right side to lift out the soft roller.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
caoimhe
979 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G5, White Fall 2018 Cal Poly, Team S17-G5, White Fall 2018 üyesi
CPSU-WHITE-F18S17G5
4 Üyeler
14 adet Kılavuz yazıldı
23 Yorum
There’s nothing blocking the soft roller in mine. I can spin it by hand. Only the regular brush roll spins. Now what?
Keith Sauer - Yanıt
I have the same problem. The gear that is connected to the motor that spins the soft brush roller is stripped. The shaft spins but the inside of the gear is stripped therefore it doesnt turn the soft brush roller. I cannot find the replacement part
Bill Pucher - Yanıt
Having this same problem
Keona Taylor -
Same here…no blockage, but won’t spin
tbridge - Yanıt
I also have the same problem. No blockage. The brush roller works but the soft roller does not spin.
Gina - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 24
Son 30 gün: 107
Her zaman: 10,213
