Giriş
Soldering skills are required.
Neye ihtiyacın var
Open the garage door by sliding both of the release buttons away from you.
Lift off the garage door.
Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
Remove one 15mm T10 screw from the inside left of the base of the vacuum to access the motherboard.
Neredeyse bitti!
Sonuç
