Ana içeriğe geç
Shark Flex DuoClean Motherboard Replacement
Neye ihtiyacın var
  1. Shark Flex DuoClean Motherboard Replacement, Garage Door: adım 1, 2 resimden 1. Shark Flex DuoClean Motherboard Replacement, Garage Door: adım 1, 2 resimden 2.
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Shark Flex DuoClean Motherboard Replacement, Side Component: adım 2, 2 resimden 1. Shark Flex DuoClean Motherboard Replacement, Side Component: adım 2, 2 resimden 2.
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
  3. Shark Flex DuoClean Motherboard Replacement: adım 3, 2 resimden 1. Shark Flex DuoClean Motherboard Replacement: adım 3, 2 resimden 2.
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
  4. Shark Flex DuoClean Motherboard Replacement: adım 4, 1 resimden 1.
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
  5. Shark Flex DuoClean Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the side component with your hands.
  6. Shark Flex DuoClean Motherboard Replacement, Top Component: adım 6, 1 resimden 1.
    • Remove the four 15 mm T10 screws on the underside of the vacuum.
  7. Shark Flex DuoClean Motherboard Replacement: adım 7, 2 resimden 1. Shark Flex DuoClean Motherboard Replacement: adım 7, 2 resimden 2.
    • Using the plastic spudger, pry the back seam of the top component to pop it off the vacuum.
  8. Shark Flex DuoClean Motherboard Replacement, Motherboard: adım 8, 1 resimden 1.
    • Remove one 15mm T10 screw from the inside left of the base of the vacuum to access the motherboard.
  9. Shark Flex DuoClean Motherboard Replacement: adım 9, 1 resimden 1.
    • Using the nylon spudger, place the curved side under the motherboard.
    • Gently pry the motherboard out of the base of the vacuum.
    • Do not use your fingers to take out the motherboard, as the bottom can be sharp.
    • The motherboard will still be connected to the base with wires.
  10. Shark Flex DuoClean Motherboard Replacement: adım 10, 1 resimden 1.
    • Desolder the motherboard wires using wire cutters.
Sonuç
Samantha Mickelson
496 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G5, White Fall 2018 Cal Poly, Team S17-G5, White Fall 2018 üyesi
CPSU-WHITE-F18S17G5
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 25
Her zaman: 1,407
