Ana içeriğe geç
Shark Flex DuoClean Power Cord Replacement
Neye ihtiyacın var
  1. Shark Flex DuoClean Power Cord Replacement, Dust Cup: adım 1, 2 resimden 1. Shark Flex DuoClean Power Cord Replacement, Dust Cup: adım 1, 2 resimden 2.
    • Squeeze Dust Cup release buttons on either side of the component.
    • Pull up to release Dust Cup.
  2. Shark Flex DuoClean Power Cord Replacement, Power Cord: adım 2, 2 resimden 1. Shark Flex DuoClean Power Cord Replacement, Power Cord: adım 2, 2 resimden 2.
    • Remove the pre-motor filter with your hands.
  3. Shark Flex DuoClean Power Cord Replacement: adım 3, 1 resimden 1.
    • Remove the post-motor filter.
  4. Shark Flex DuoClean Power Cord Replacement: adım 4, 1 resimden 1.
    • Remove the two 15 mm screws by twisting counterclockwise with the T10 Torx screwdriver.
  5. Shark Flex DuoClean Power Cord Replacement: adım 5, 2 resimden 1. Shark Flex DuoClean Power Cord Replacement: adım 5, 2 resimden 2.
    • Remove the two 12 mm screws by twisting counterclockwise with the T15 Torx screwdriver.
    • To fully remove the power cord, cut the wires using a wire cutter.
    • For reassembly, use the soldering guide in the Introduction.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
caoimhe
979 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G5, White Fall 2018 Cal Poly, Team S17-G5, White Fall 2018 üyesi
CPSU-WHITE-F18S17G5
4 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
I found with further dissasembly, uncrimping and recrimping the wiring loom saved having to add more connections.
qwazew - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 21
Her zaman: 1,389
