Ana içeriğe geç
Shark Flex DuoClean Suction Motor Replacement
Neye ihtiyacın var
  1. Shark Flex DuoClean Suction Motor Replacement, Dust Cup: adım 1, 2 resimden 1. Shark Flex DuoClean Suction Motor Replacement, Dust Cup: adım 1, 2 resimden 2.
    • Squeeze Dust Cup release buttons on either side of the component.
    • Pull up to release Dust Cup.
  2. Shark Flex DuoClean Suction Motor Replacement, Suction Motor: adım 2, 1 resimden 1.
    • Remove the five 15 mm screws by twisting counterclockwise with a T10 Torx screwdriver.
  3. Shark Flex DuoClean Suction Motor Replacement: adım 3, 1 resimden 1.
    • Use the iFixit opening tool to remove the top component.
  4. Shark Flex DuoClean Suction Motor Replacement: adım 4, 1 resimden 1.
    • Remove the two 15mm screws by twisting counterclockwise using the T10 Torx screwdriver.
  5. Shark Flex DuoClean Suction Motor Replacement: adım 5, 1 resimden 1.
    • Remove the two 15 mm screws by twisting counterclockwise with a T10 Torx screwdriver.
  6. Shark Flex DuoClean Suction Motor Replacement: adım 6, 1 resimden 1.
    • Remove the two 15 mm screws holding the motor cover by twisting counterclockwise with a T10 Torx screwdriver.
  7. Shark Flex DuoClean Suction Motor Replacement: adım 7, 1 resimden 1.
    • Cut the zip ties holding the motor using the wire cutter.
  8. Shark Flex DuoClean Suction Motor Replacement: adım 8, 1 resimden 1.
    • Cut the wires using the wire cutters to completely remove the motor.
    • For reassembly, use the soldering guide in the Introduction.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Christian Fuller
420 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G5, White Fall 2018 Cal Poly, Team S17-G5, White Fall 2018 üyesi
CPSU-WHITE-F18S17G5
4 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
how i need to know how to re connect the wires on replacing a new motor, my model is similar HV321.
andrea - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 28
Her zaman: 3,495
