Ana içeriğe geç
Shark ION RV754 Filter Replacement
Neye ihtiyacın var
    1. Shark ION RV754 Filter Replacement, Dust Filter(s): adım 1, 1 resimden 1.
      • Flip the robot vacuum upside down so the wheels are facing up.
      • Press the dust bin removal latch and slide out the dust bin.
      FixBot'a Sor
      Yorum Ekle
    2. Shark ION RV754 Filter Replacement: adım 2, 1 resimden 1.
      • Pull out the blue filter on the inside of the dust tray.
      • This filter is not attached to anything and should come out easily.
      FixBot'a Sor
      Yorum Ekle
    3. Shark ION RV754 Filter Replacement: adım 3, 1 resimden 1.
      • To access the second filter, open the debris tray.
      • Hold the tray with two fingers at the indicated holes, and use your other hand to pull from the opposite side of the tray.
      FixBot'a Sor
      Yorum Ekle
    4. Shark ION RV754 Filter Replacement: adım 4, 3 resimden 1. Shark ION RV754 Filter Replacement: adım 4, 3 resimden 2. Shark ION RV754 Filter Replacement: adım 4, 3 resimden 3.
      • Use a Phillips #0 screwdriver to remove the 7.3 mm screw securing the second filter.
      • Lift the filter out from the same side where you removed the screw.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
James Holland
370 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 36
Her zaman: 370
