Ana içeriğe geç
Shark ION Robot 750 Charging Dock Motherboard Replacement
Neye ihtiyacın var
  1. Shark ION Robot 750 Charging Dock Motherboard Replacement, Charging Dock: adım 1, 1 resimden 1.
    • Remove the three Torx T6 screws on the underside of the charging dock.
    • Lift off the lower case.
  2. Shark ION Robot 750 Charging Dock Motherboard Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #0 screwdriver, unscrew the four screws inside.
  3. Shark ION Robot 750 Charging Dock Motherboard Replacement: adım 3, 2 resimden 1. Shark ION Robot 750 Charging Dock Motherboard Replacement: adım 3, 2 resimden 2.
    • Gently push in the tabs to remove the sensor housing.
  4. Shark ION Robot 750 Charging Dock Motherboard Replacement: adım 4, 1 resimden 1.
    • Unplug the two wires going into the motherboard, then gently lift the motherboard up and out of its slot.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 116
