Ana içeriğe geç
Shark ION Robot 750 Outer Shell Replacement
Neye ihtiyacın var
  1. Shark ION Robot 750 Outer Shell Replacement, Outer Shell: adım 1, 3 resimden 1. Shark ION Robot 750 Outer Shell Replacement, Outer Shell: adım 1, 3 resimden 2. Shark ION Robot 750 Outer Shell Replacement, Outer Shell: adım 1, 3 resimden 3.
    • Make sure the device is completely powered off before working.
    • Flip over the vacuum on a flat and uncluttered service with the bottom facing upwards.
    • Remove all seven 9.1mm Torx T15 screws from the device’s front bumper.
    • Remove the nine 9.1mm Torx T6 bolts from outer shell.
  2. Shark ION Robot 750 Outer Shell Replacement: adım 2, 2 resimden 1. Shark ION Robot 750 Outer Shell Replacement: adım 2, 2 resimden 2.
    • Slightly pull front bumper to expose internal wiring.
    • Unplug the device’s front bumper wiring and completely remove front bumper.
  3. Shark ION Robot 750 Outer Shell Replacement: adım 3, 2 resimden 1. Shark ION Robot 750 Outer Shell Replacement: adım 3, 2 resimden 2.
    • Remove the four 9.5mm Torx T6 bolts on the yellow brush frame.
    • Gently depress the two tabs on the frame, then lift the frame to remove it.
  4. Shark ION Robot 750 Outer Shell Replacement: adım 4, 2 resimden 1. Shark ION Robot 750 Outer Shell Replacement: adım 4, 2 resimden 2.
    • Pick up the brush and remove it from the vacuum.
    • Push the brush to your right and lift it.
  5. Shark ION Robot 750 Outer Shell Replacement: adım 5, 3 resimden 1. Shark ION Robot 750 Outer Shell Replacement: adım 5, 3 resimden 2. Shark ION Robot 750 Outer Shell Replacement: adım 5, 3 resimden 3.
    • Press and hold the dust bin removal button to slide out the dust bin.
  6. Shark ION Robot 750 Outer Shell Replacement: adım 6, 1 resimden 1.
    • Lift the outer shell to expose the Shark’s interior.
Sonuç
Youness Elfath
183 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 245
