Ana içeriğe geç
Shark ION Robot R75 Caster Wheel Replacement
Neye ihtiyacın var
  1. Shark ION Robot R75 Caster Wheel Replacement, Shark ION Robot R75 Caster Wheel: adım 1, 1 resimden 1.
    • Orient the device with the bottom facing up.
    FixBot'a Sor
    Yorum Ekle
  2. Shark ION Robot R75 Caster Wheel Replacement: adım 2, 3 resimden 1. Shark ION Robot R75 Caster Wheel Replacement: adım 2, 3 resimden 2. Shark ION Robot R75 Caster Wheel Replacement: adım 2, 3 resimden 3.
    • Using a plastic opening tool, pry first one side of the wheel, then the other out of the caster.
    • Remove the wheel.
    FixBot'a Sor
    Yorum Ekle
  3. Shark ION Robot R75 Caster Wheel Replacement: adım 3, 3 resimden 1. Shark ION Robot R75 Caster Wheel Replacement: adım 3, 3 resimden 2. Shark ION Robot R75 Caster Wheel Replacement: adım 3, 3 resimden 3.
    • Using a Torx TR9 screwdriver, remove both screws from the caster assembly beneath the wheel.
    • Pull the caster assembly up from its slot in the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
1Rehber Yorum
Thanks, my compliments to your clear, simple instructions. And I love my shark AV2500 self-emptying machine--but when will manufactures realize small buy normal Philips screwheads doesn't cost more than chump change on a unit but make it A WHOLE LOT EASYER ON THEIR CUTOMERS.
Dennis King - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 59
Her zaman: 6,111
