Ana içeriğe geç
Shark IONFlex 2X Brush Roll Band Replacement
Neye ihtiyacın var
  1. Shark IONFlex 2X Brush Roll Band Replacement, Brush Roll Band: adım 1, 1 resimden 1.
    • Press and slide the “access brush roll” buttons towards the text and lift plastic brush roll cover off.
  2. Shark IONFlex 2X Brush Roll Band Replacement: adım 2, 2 resimden 1. Shark IONFlex 2X Brush Roll Band Replacement: adım 2, 2 resimden 2.
    • Gently pry the circular screw cover off of the side of the casing with the shoe print mark on it with the small metal spudger.
  3. Shark IONFlex 2X Brush Roll Band Replacement: adım 3, 1 resimden 1.
    • Use a T20 screwdriver to unscrew the 12.3 mm screw beneath the cover you just removed.
  4. Shark IONFlex 2X Brush Roll Band Replacement: adım 4, 2 resimden 1. Shark IONFlex 2X Brush Roll Band Replacement: adım 4, 2 resimden 2.
    • Move to the side of the casing with the shoe print mark. Use the T20 screwdriver to unscrew the 18mm screw.
  5. Shark IONFlex 2X Brush Roll Band Replacement: adım 5, 3 resimden 1. Shark IONFlex 2X Brush Roll Band Replacement: adım 5, 3 resimden 2. Shark IONFlex 2X Brush Roll Band Replacement: adım 5, 3 resimden 3.
    • Use the small metal spudger to gently separate the side casing from the main body.
  6. Shark IONFlex 2X Brush Roll Band Replacement: adım 6, 1 resimden 1.
    • Use the large plastic opening tool to pry the rubber brushroll band towards you until the rubber brush roll band comes off of the small metal gear.
  7. Shark IONFlex 2X Brush Roll Band Replacement: adım 7, 2 resimden 1. Shark IONFlex 2X Brush Roll Band Replacement: adım 7, 2 resimden 2.
    • Pull the rubber brush roll band out of the large white gear.
Sonuç
Bir başkası bu kılavuzu tamamladı.
3 Yorum
You also forgot one of the most important parts when it comes to taking this apart. Which is taking the top off to get to motor I had solid lights which where the rug and floor lights and the vacuum would turn off which indicates that there is something going on with the motor. Unfortunately you didn’t have a picture on how to do so I had to break some parts to figure it out. So where the lights are its actually a sticker so you peal it off to get to the hidden screws to take the top off to get to the motor. After so long having this vacuum the dust can build up and clog the circuits where the motor is. I took Isopropyl alcohol 99% and used a tooth brush and scrubbed it and dried it and put the battery back in before putting everything back together and it worked perfectly again. Hope this helps out anyone else in the future so much better then buying a new vacuum.
Tyler - Yanıt
Were do you find a belt?
hmd1974 - Yanıt
Can't I just replace the floor nozzle in its entirety.
Patti P
YorkieMom - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 41
Her zaman: 6,149
