Ana içeriğe geç
Shark IQ AV993 Battery Replacement
Neye ihtiyacın var
  1. Shark IQ AV993 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Unscrew the two 14 mm screws on the battery panel using a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Shark IQ AV993 Battery Replacement: adım 2, 1 resimden 1.
    • Gently pull the white tabs on the battery straight upward.
    • There is a clip inserted into a plastic housing via wiring. Disconnect the battery by pressing in the clip.
    • Don't pull up on the battery too hard as a wire connects to the robot. Don't want to damage the wire here.
    • Remove the battery from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Kyle Rhines
600 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-3, Botvin Fall 2022 UMass Dartmouth, Team 3-3, Botvin Fall 2022 üyesi
UMASSD-BOTVIN-F22S3G3
3 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
This guide is also applicable to the Shark Matrix UR2360S. Thanks!
pyt - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 36
Her zaman: 713
