Giriş
If the handle for your Steam Pocket Mop gets loose and falls off, or if you would like to remove the handle for easy storage, use this guide to walk you through the process. You will need a Phillips #2 screwdriver for this replacement.
Neye ihtiyacın var
To disassemble your device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
