Ana içeriğe geç
Shark Matrix RV2310 Wheel Assembly Replacement
Neye ihtiyacın var
  1. Shark Matrix RV2310 Wheel Assembly Replacement, Battery: adım 1, 3 resimden 1. Shark Matrix RV2310 Wheel Assembly Replacement, Battery: adım 1, 3 resimden 2. Shark Matrix RV2310 Wheel Assembly Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the two 11 mm Phillips screws holding the battery plate in place.
    • Remove the battery plate.
  2. Shark Matrix RV2310 Wheel Assembly Replacement: adım 2, 3 resimden 1. Shark Matrix RV2310 Wheel Assembly Replacement: adım 2, 3 resimden 2. Shark Matrix RV2310 Wheel Assembly Replacement: adım 2, 3 resimden 3.
    • Remove the battery from the compartment.
    • Disconnect the electrical cable connection from the battery to the robot.
  3. Shark Matrix RV2310 Wheel Assembly Replacement, Wheel Assembly: adım 3, 2 resimden 1. Shark Matrix RV2310 Wheel Assembly Replacement, Wheel Assembly: adım 3, 2 resimden 2.
    • Remove the five 11 mm Phillips screws holding the wheel assembly in place.
    • Make sure the device's battery has been fully removed from the device before proceeding. Failure to do so could potentially result in minor/moderate injuries.
  4. Shark Matrix RV2310 Wheel Assembly Replacement: adım 4, 1 resimden 1.
    • Lift the wheel assembly out of the vacuum.
    • Do not pull or tug too hard on the wheel when lifting it, as there is a wire connection between the wheel and the motherboard.
  5. Shark Matrix RV2310 Wheel Assembly Replacement: adım 5, 1 resimden 1.
    • Undo the wire connection between the motherboard and the wheel assembly by gently pulling the wire out from the wheel assembly's connector.
Sonuç
Joshua Correia
631 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-4, Botvin Spring 2024 UMass Dartmouth, Team 6-4, Botvin Spring 2024 üyesi
UMASSD-BOTVIN-S24S6G4
2 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 51
Her zaman: 568
