Ana içeriğe geç
Shark NV352 Filter Replacement
  1. Shark NV352 Filter Replacement, Filter: adım 1, 1 resimden 1.
    • Ensure that you are removing the filters from the vacuum in an area that you don't mind getting dirty because the filters will be very dusty.
    • Lift the latches on both sides of the vacuum to release the dust canister.
    FixBot'a Sor
    Yorum Ekle
  2. Shark NV352 Filter Replacement: adım 2, 2 resimden 1. Shark NV352 Filter Replacement: adım 2, 2 resimden 2.
    • Tilt the dust canister forward to release it from its position.
    • Carefully lift away the dust canister and set it aside.
    FixBot'a Sor
    Yorum Ekle
  3. Shark NV352 Filter Replacement: adım 3, 3 resimden 1. Shark NV352 Filter Replacement: adım 3, 3 resimden 2. Shark NV352 Filter Replacement: adım 3, 3 resimden 3.
    • Remove the upper filter by lifting upwards on it.
    • Now that the lower filter is exposed, remove it by pulling it upwards.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Vincent Leuzze
309 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G5, Forte Fall 2017 Cal Poly, Team S18-G5, Forte Fall 2017 üyesi
CPSU-FORTE-F17S18G5
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 36
Her zaman: 1,457
