Ana içeriğe geç
Shark NV352 Roller Brush Replacement
Neye ihtiyacın var
  1. Shark NV352 Roller Brush Replacement, Roller Brush: adım 1, 2 resimden 1. Shark NV352 Roller Brush Replacement, Roller Brush: adım 1, 2 resimden 2.
    • Lift the latches on both sides of the vacuum to release the dust canister.
    • Remove the dust canister from the vacuum by lifting it up.
  2. Shark NV352 Roller Brush Replacement: adım 2, 1 resimden 1.
    • Lay down the vacuum to access the bottom panel of the roller brush compartment.
  3. Shark NV352 Roller Brush Replacement: adım 3, 2 resimden 1. Shark NV352 Roller Brush Replacement: adım 3, 2 resimden 2.
    • Using the metal spudger, pry the two small wheels located at the two bottom corners of the vacuum to remove them.
  4. Shark NV352 Roller Brush Replacement: adım 4, 2 resimden 1. Shark NV352 Roller Brush Replacement: adım 4, 2 resimden 2.
    • Remove the eight 19mm Phillips #2 screws from the plastic cover.
    • Remove the two 14 mm Phillips #2 screws from the upper section of the plastic cover.
  5. Shark NV352 Roller Brush Replacement: adım 5, 2 resimden 1. Shark NV352 Roller Brush Replacement: adım 5, 2 resimden 2.
    • You will need to apply a strong force while pulling the wheels off because they are attached very tightly.
    • Remove the wheels by pulling them out of their axles, away from the vacuum.
  6. Shark NV352 Roller Brush Replacement: adım 6, 2 resimden 1. Shark NV352 Roller Brush Replacement: adım 6, 2 resimden 2.
    • Perform the next step slowly and carefully so the wiring connecting the motherboard to the rest of the vacuum is not broken.
    • Gently pull the grey lower part of the roller brush compartment away from the purple upper part of the compartment.
  7. Shark NV352 Roller Brush Replacement: adım 7, 1 resimden 1.
    • Lift up and then pull the roller belt off of the roller brush and the motor to remove it.
  8. Shark NV352 Roller Brush Replacement: adım 8, 1 resimden 1.
    • Take out the roller brush by lifting it out of its tray.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Amy Moran
603 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G5, Forte Fall 2017 Cal Poly, Team S18-G5, Forte Fall 2017 üyesi
CPSU-FORTE-F17S18G5
4 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
FOR SOME MODELS - THE BRUSH WILL NOT OPERATE IN AN UPRIGHT POSITION.
Shark navigator 350-353 series - if you have cleaned the roller and it doesn't work, TILT THE HANDLE BACK then try.
elaina heinz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 19
Son 30 gün: 71
Her zaman: 4,695
