Ana içeriğe geç
Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement
  1. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement, Foam and Felt Filters: adım 1, 1 resimden 1.
    • Locate the latches on the side of the dust cup, the clear plastic chamber in the center of the vacuum.
  2. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: adım 2, 3 resimden 1. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: adım 2, 3 resimden 2. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: adım 2, 3 resimden 3.
    • Pull the bottom of the latch with your hand in an upward direction.
    • Lift the top of the latch up and away from the dust cup using your hand.
    • Repeat the above steps with the latch on the other side of the dust cup.
  3. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: adım 3, 2 resimden 1. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: adım 3, 2 resimden 2.
    • Lift the dust cup up and away by its handle on the top with your hands.
  4. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: adım 4, 3 resimden 1. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: adım 4, 3 resimden 2. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: adım 4, 3 resimden 3.
    • Lift the foam filter up, out, and away with your hands.
  5. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: adım 5, 3 resimden 1. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: adım 5, 3 resimden 2. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: adım 5, 3 resimden 3.
    • Lift the felt filter up, out, and away with your hands by the tab on the top.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Pramika Kumar
258 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G2, Livingston Fall 2017 Cal Poly, Team S15-G2, Livingston Fall 2017 üyesi
CPSU-LIVINGSTON-F17S15G2
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 19
Son 30 gün: 54
Her zaman: 5,055
