Ana içeriğe geç
Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement
Neye ihtiyacın var
  1. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement, Roller Brush Belt: adım 1, 2 resimden 1. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement, Roller Brush Belt: adım 1, 2 resimden 2.
    • Lay the vacuum down by hand and locate the roller brush underneath the vacuum cleaner.
  2. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: adım 2, 3 resimden 1. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: adım 2, 3 resimden 2. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: adım 2, 3 resimden 3.
    • Insert the metal spudger between the inside side of the wheel and the plastic body.
    • Push the metal spudger away from you to pop the wheels out.
    • Repeat the step to remove the other wheel on the other side.
  3. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: adım 3, 1 resimden 1.
    • Remove the six 15mm screws using the PH1 screwdriver.
  4. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: adım 4, 2 resimden 1. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: adım 4, 2 resimden 2.
    • Move the blue fulcrum connecting the bottom and the main body of the vacuum cleaner back and forth to loosen up crevice between the two halves of the roller brush enclosure.
  5. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: adım 5, 3 resimden 1. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: adım 5, 3 resimden 2. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: adım 5, 3 resimden 3.
    • Insert the plastic opening tool into the crevice between the blue and the dark grey plastic frames enclosing the roller brush.
    • Apply an outward force throughout and all around the gap in order to separate the two plastic frames.
  6. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: adım 6, 2 resimden 1. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: adım 6, 2 resimden 2.
    • Lift the grey frame off the bottom of the vacuum cleaner with your hands and place it on a flat surface.
  7. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: adım 7, 3 resimden 1. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: adım 7, 3 resimden 2. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: adım 7, 3 resimden 3.
    • Lift the roller brush slightly upwards using your hand.
    • Take one side of the black roller brush belt off by pulling it over the end of the roller brush with your other hand.
  8. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: adım 8, 1 resimden 1.
    • Remove the roller brush belt with your hands by sliding it of the end of the motor.
  9. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement, Roller Brush: adım 9, 2 resimden 1. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement, Roller Brush: adım 9, 2 resimden 2.
    • Remove the roller brush from the plastic frame using your hands by lifting it away.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Elena Postupalskaya
1.177 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G2, Livingston Fall 2017 Cal Poly, Team S15-G2, Livingston Fall 2017 üyesi
CPSU-LIVINGSTON-F17S15G2
3 Üyeler
14 adet Kılavuz yazıldı
3 Yorum
What is the part number for the roller brush?
Sean E. Belew - Yanıt
what is the part number for the motor and motherboard
benjpatt - Yanıt
Worst screw types. You suck
Ace - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 33
Son 7 gün: 131
Son 30 gün: 539
Her zaman: 43,552
