Ana içeriğe geç
Shark Navigator Lightweight Upright Head Shell Replacement
Neye ihtiyacın var
  1. Shark Navigator Lightweight Upright Head Shell Replacement, Head Shell: adım 1, 2 resimden 1. Shark Navigator Lightweight Upright Head Shell Replacement, Head Shell: adım 1, 2 resimden 2.
    • Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
  2. Shark Navigator Lightweight Upright Head Shell Replacement: adım 2, 2 resimden 1. Shark Navigator Lightweight Upright Head Shell Replacement: adım 2, 2 resimden 2.
    • Lay the vacuum on its side.
    • Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
  3. Shark Navigator Lightweight Upright Head Shell Replacement: adım 3, 1 resimden 1.
    • Flip over the vacuum head so the brush head is facing up.
  4. Shark Navigator Lightweight Upright Head Shell Replacement: adım 4, 3 resimden 1. Shark Navigator Lightweight Upright Head Shell Replacement: adım 4, 3 resimden 2. Shark Navigator Lightweight Upright Head Shell Replacement: adım 4, 3 resimden 3.
    • Remove the small front wheels with a metal spudger by inserting the metal spudger in front of the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it.
    • Repeat this for the other wheel.
  5. Shark Navigator Lightweight Upright Head Shell Replacement: adım 5, 2 resimden 1. Shark Navigator Lightweight Upright Head Shell Replacement: adım 5, 2 resimden 2.
    • Remove the two 18mm screws with a JIS 1 screwdriver.
  6. Shark Navigator Lightweight Upright Head Shell Replacement: adım 6, 2 resimden 1. Shark Navigator Lightweight Upright Head Shell Replacement: adım 6, 2 resimden 2.
    • Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
  7. Shark Navigator Lightweight Upright Head Shell Replacement: adım 7, 2 resimden 1. Shark Navigator Lightweight Upright Head Shell Replacement: adım 7, 2 resimden 2.
    • Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
  8. Shark Navigator Lightweight Upright Head Shell Replacement: adım 8, 3 resimden 1. Shark Navigator Lightweight Upright Head Shell Replacement: adım 8, 3 resimden 2. Shark Navigator Lightweight Upright Head Shell Replacement: adım 8, 3 resimden 3.
    • Remove the plastic cover by prying the plastic cover up using a plastic opening tool.
    • Prying in multiple locations may be necessary to create separation.
Sonuç
Suzie
534 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S4-G6, Livingston Fall 2017 Cal Poly, Team S4-G6, Livingston Fall 2017 üyesi
CPSU-LIVINGSTON-F17S4G6
3 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
I have been doing exactly what the steps require but have not been able to remove the cover. Each time I am able to release one side the other side snaps back and the fixit tools fall out or fall inside.
Please give me any suggestions to accomplish removing the cover. Thank you.
Diane Snelling - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 1,142
