Ana içeriğe geç
Shark Navigator Lightweight Upright Motor Replacement
Neye ihtiyacın var
    1. Shark Navigator Lightweight Upright Motor Replacement, Head Shell: adım 1, 2 resimden 1. Shark Navigator Lightweight Upright Motor Replacement, Head Shell: adım 1, 2 resimden 2.
      • Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
      FixBot'a Sor
      Yorum Ekle
    2. Shark Navigator Lightweight Upright Motor Replacement: adım 2, 2 resimden 1. Shark Navigator Lightweight Upright Motor Replacement: adım 2, 2 resimden 2.
      • Lay the vacuum on its side.
      • Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
      FixBot'a Sor
      Yorum Ekle
    3. Shark Navigator Lightweight Upright Motor Replacement: adım 3, 1 resimden 1.
      • Flip over the vacuum head so the brush head is facing up.
      FixBot'a Sor
      Yorum Ekle
    4. Shark Navigator Lightweight Upright Motor Replacement: adım 4, 3 resimden 1. Shark Navigator Lightweight Upright Motor Replacement: adım 4, 3 resimden 2. Shark Navigator Lightweight Upright Motor Replacement: adım 4, 3 resimden 3.
      • Remove the small front wheels with a metal spudger by inserting the metal spudger in front of the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it.
      • Repeat this for the other wheel.
      FixBot'a Sor
      Yorum Ekle
    5. Shark Navigator Lightweight Upright Motor Replacement: adım 5, 2 resimden 1. Shark Navigator Lightweight Upright Motor Replacement: adım 5, 2 resimden 2.
      • Remove the two 18mm screws with a JIS 1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. Shark Navigator Lightweight Upright Motor Replacement: adım 6, 2 resimden 1. Shark Navigator Lightweight Upright Motor Replacement: adım 6, 2 resimden 2.
      • Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    7. Shark Navigator Lightweight Upright Motor Replacement: adım 7, 2 resimden 1. Shark Navigator Lightweight Upright Motor Replacement: adım 7, 2 resimden 2.
      • Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    8. Shark Navigator Lightweight Upright Motor Replacement: adım 8, 3 resimden 1. Shark Navigator Lightweight Upright Motor Replacement: adım 8, 3 resimden 2. Shark Navigator Lightweight Upright Motor Replacement: adım 8, 3 resimden 3.
      • Remove the plastic cover by prying the plastic cover up using a plastic opening tool.
      • Prying in multiple locations may be necessary to create separation.
      FixBot'a Sor
      Yorum Ekle
    1. Shark Navigator Lightweight Upright Motor Replacement, Motor: adım 9, 1 resimden 1.
      • Locate the motor on the top right corner of the vacuum head shell.
      FixBot'a Sor
      Yorum Ekle
    2. Shark Navigator Lightweight Upright Motor Replacement: adım 10, 3 resimden 1. Shark Navigator Lightweight Upright Motor Replacement: adım 10, 3 resimden 2. Shark Navigator Lightweight Upright Motor Replacement: adım 10, 3 resimden 3.
      • Remove the belt from the motor gear by sliding the belt to the right.
      FixBot'a Sor
      Yorum Ekle
    3. Shark Navigator Lightweight Upright Motor Replacement: adım 11, 3 resimden 1. Shark Navigator Lightweight Upright Motor Replacement: adım 11, 3 resimden 2. Shark Navigator Lightweight Upright Motor Replacement: adım 11, 3 resimden 3.
      • Remove the white metal wire connector from the motor.
      • The white cable is positive.
      FixBot'a Sor
      Yorum Ekle
    4. Shark Navigator Lightweight Upright Motor Replacement: adım 12, 2 resimden 1. Shark Navigator Lightweight Upright Motor Replacement: adım 12, 2 resimden 2.
      • Remove the black metal wire connector from the motor.
      • The black cable is negative.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Suzie
545 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S4-G6, Livingston Fall 2017 Cal Poly, Team S4-G6, Livingston Fall 2017 üyesi
CPSU-LIVINGSTON-F17S4G6
3 Üyeler
46 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where does one buy the replacement motor?
Michael De La Rosa - Yanıt Paylaş
Where can I get spares??
ck
Clive Kingscote - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 13
Son 30 gün: 52
Her zaman: 10,598
