Ana içeriğe geç
Shark Navigator Motherboard Replacement
Neye ihtiyacın var
  1. Shark Navigator Motherboard Replacement, Roller Brush Compartment: adım 1, 1 resimden 1.
    • Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
  2. Shark Navigator Motherboard Replacement: adım 2, 2 resimden 1. Shark Navigator Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
    • The screws have varying lengths, so keep track of where each one goes for reassembly.
  3. Shark Navigator Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the white plastic cover to expose the roller compartment underneath.
  4. Shark Navigator Motherboard Replacement, Motherboard: adım 4, 1 resimden 1.
    • There is one screw at the edge of the circuit board. Unscrew the circuit board before attempting to take it out.
  5. Shark Navigator Motherboard Replacement: adım 5, 1 resimden 1.
    • Take out the circuit board and replace with a new one. It may be better to allow a professional to re-wire the circuit board to the vacuum.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Mara
469 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-4, Kish Spring 2015 UMass Dartmouth, Team 5-4, Kish Spring 2015 üyesi
UMASSD-KISH-S15S5G4
4 Üyeler
16 adet Kılavuz yazıldı
8 Yorum
Hi ..well done with the instructions.However I do have a Shark rotator vacuum NV501 .Unfortunately the motor on the brush is not working ,so I assume the motor is burnt.My request where could I find a replacement of the motor.I have searched a lot sites online but could not find a place to rebuild nor stock the same motor.Any help would be appreciated.Thank you.....To forward any information please do so on my email jacob.brown at hotmail.com thank you....
jacob - Yanıt
I couldn't figure out how to remove the bottom plate, your guide helped by informing me the last two screws are located under the little wheels. Thank you!
dylananon - Yanıt
When I had mine apart, two black rectangle magnet fell out, I can't figure out where the came from.
mardit - Yanıt
I had the same problem with the magnets - where do they go>
bjolivares1055 -
Also having problem locating both mother board and brush roller motor. Where can i purchase them?
Liz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 7,689
