Neye ihtiyacın var
Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
Screws under the wheels? Seriously? Who does that? Is Shark trying to make their vacuum like the cars are today? Working on cars together with their Dad was something guys (or girls) used to do when I was growing up. It was about bonding and learning about how things worked and also kept the car running. Kids don't get to do that anymore. Sadly appliances are apparently going the same way. It's unfortunate.
All this just to take the roller brush off; -(
Y'all need an raiser way to take the roller brush off , this is REDICULIOUS.
To clean it and I actually just did mine wasn’t necessary to take it apart. Took me less than 10 minutes to do. I separated the bottom part and flipped it over. While holding it i took a sharp razor blade and made small repeated strokes cutting hair and debris. It did one section at a time then pinched it out with my hands. Vacuum is now spotless and didn’t have to go through the hassle of removing all those screws unless you need to replace the roller that is
Changing brush roller is the worst process I've seen…brain surgery would be easier. I'm cannot believe you ruined a great vacuum cleaner. You get one star fot that.
My screws have little bumps in the center so how on he'll do you get a pointed Phillips head in there to turn the screw?
same issue here… must be on the later models.. looks like you need a special tool to get these screws out… look like hexagonal screw heads…
after some digging around this is what I found:
It should be noted that on some models you will need a T-20 security head (star-bit) driver to access the brush assembly. Of more importance, you will need at least a 3 inch bit, or single driver with a 3-inch stem, but do NOT try to use a 1/4 inch hex bit extender as the connector shank will be too wide to fit down the narrow screw wells.
This comment was provided in the comment section of this video:
I just did mine. The original post is no longer correct, nor is the last post. The screws are all Security Torx, size T15. I hight suggest getting three inch (skinny shank) bits. Normal size bits will NOT work because the screws are too recessed. Some thing like this should do…
Tonsiki 11 Pieces 1/4 Inch Hex Shank T6-T40 3 Inch Length S2 Steel Torx Security Head Screwdriver Drill Set Bits https://www.amazon.com/dp/B01MFGRZIA/ref...
Thank you for showing where ALL the screws are that need to be removed. SHARK, terribly bad design just to get to roller. AND, I have spent two days trying to get the right tool-two screw are phillips head and the rest require a security T15 torx bit and the two Under The Phillips head screws have to have a longer bit than the rest! Most difficult brand I’ve ever used!
Remove the white plastic cover to expose the roller compartment underneath.
I removed all 10 screws, but the roller brush compartment still didn’t open. Mine is the Shark Navigator Lift Away, is it too different of a model?
There is one screw at the edge of the circuit board. Unscrew the circuit board before attempting to take it out.
3 farklı kişi bu kılavuzu tamamladı.
8 Yorum
Hi ..well done with the instructions.However I do have a Shark rotator vacuum NV501 .Unfortunately the motor on the brush is not working ,so I assume the motor is burnt.My request where could I find a replacement of the motor.I have searched a lot sites online but could not find a place to rebuild nor stock the same motor.Any help would be appreciated.Thank you.....To forward any information please do so on my email jacob.brown at hotmail.com thank you....
When I had mine apart, two black rectangle magnet fell out, I can't figure out where the came from.
I had the same problem with the magnets - where do they go>
So when I had my vacuum apart, a spring fell out…where would that be from? How do I get it back in?
No power in brush roller bar.
Allan Kircher - Yanıt
