Ana içeriğe geç
Shark Navigator Motor Replacement
Neye ihtiyacın var
  1. Shark Navigator Motor Replacement, Roller Brush Compartment: adım 1, 1 resimden 1.
    • Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
  2. Shark Navigator Motor Replacement: adım 2, 2 resimden 1. Shark Navigator Motor Replacement: adım 2, 2 resimden 2.
    • Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
    • The screws have varying lengths, so keep track of where each one goes for reassembly.
  3. Shark Navigator Motor Replacement: adım 3, 1 resimden 1.
    • Remove the white plastic cover to expose the roller compartment underneath.
  4. Shark Navigator Motor Replacement, Motor: adım 4, 1 resimden 1.
    • Once the vacuum top is opened, you can simply remove the motor as shown in the image.
    • Make sure to untangle or unhook any wires that are connected to the motor.
    • Once this is done, you can replace the old motor with a new one.
Sonuç
Molina Oung
289 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-4, Kish Spring 2015 UMass Dartmouth, Team 5-4, Kish Spring 2015 üyesi
UMASSD-KISH-S15S5G4
4 Üyeler
16 adet Kılavuz yazıldı
6Kılavuz Yorumları
Hi Where could I get a replacement motor from for NV501 model shark rotator .Or have the same motor rebuilt...Any help would be appreciated thank you.....
jacob - Yanıt
The screws on the bottom of roller brush compartment ARE NOT phillips head!!!!!!!!!!!!!!!!!!!!
randy - Yanıt
The screws are Phillips on mine. It may be a case of availability. If the manufacturer found a better deal on a different style of screw, they may have changed it.
Joe Evans -
Mine has the security Torx screws. Those are the Torx bits with a round hole in the center. Anyway, what is the model number of the motor? I need a replacement motor, and am finding several in eBay but don't know which one is correct.
Roger -
Have no suction but the roller still spins can it still be the Motor ?
Thompson Mick - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 24
Son 30 gün: 123
Her zaman: 17,593
