Ana içeriğe geç
Shark Navigator Roller Brush Replacement
Neye ihtiyacın var
  1. Shark Navigator Roller Brush Replacement, Roller Brush Compartment: adım 1, 1 resimden 1.
    • Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
  2. Shark Navigator Roller Brush Replacement: adım 2, 2 resimden 1. Shark Navigator Roller Brush Replacement: adım 2, 2 resimden 2.
    • Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
    • The screws have varying lengths, so keep track of where each one goes for reassembly.
  3. Shark Navigator Roller Brush Replacement: adım 3, 1 resimden 1.
    • Remove the white plastic cover to expose the roller compartment underneath.
  4. Shark Navigator Roller Brush Replacement, Roller Brush: adım 4, 1 resimden 1.
    • Lift the roller brush out of its holders.
Sonuç
42 farklı kişi bu kılavuzu tamamladı.
Jeremiah Shyne
1.403 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-4, Kish Spring 2015 UMass Dartmouth, Team 5-4, Kish Spring 2015 üyesi
UMASSD-KISH-S15S5G4
4 Üyeler
16 adet Kılavuz yazıldı
35 Yorum
Instructions where so easy to follow & right on the money. It took me 11 min from start to finish. PERFECT!!!
Cole bohn - Yanıt
Very helpful and easy. Thank you.
Kristi cox - Yanıt
Thank you. The owner's manual doesn't take into account needing to disassemble to clean the brush, for those of us with super long hair. Your instructions pointed out the screws under the wheels that we were missing.
birdofpyre - Yanıt
Ive uscrewed everything and this white piece seems to be stuck toward the rear. I even took the back whells off.
falynkinsey - Yanıt
Thank you so much. After having had to send in vac due to recall could not bare to part with it again to fix the belt. Your instructions for very clear and easy to follow. Thank you June
interhome1 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 31
Son 30 gün: 258
Her zaman: 101,899
