Ana içeriğe geç
Shark Pet Perfect II Battery Replacement
Neye ihtiyacın var
  1. Shark Pet Perfect II Battery Replacement, Battery: adım 1, 3 resimden 1. Shark Pet Perfect II Battery Replacement, Battery: adım 1, 3 resimden 2. Shark Pet Perfect II Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Locate and remove the 7.5mm Philips screw holding the battery cover in place on bottom of the vacuum.
    FixBot'a Sor
    Yorum Ekle
  2. Shark Pet Perfect II Battery Replacement: adım 2, 3 resimden 1. Shark Pet Perfect II Battery Replacement: adım 2, 3 resimden 2. Shark Pet Perfect II Battery Replacement: adım 2, 3 resimden 3.
    • Once the cover is removed, slide the plastic retaining bracket down and pull out to remove.
    FixBot'a Sor
    Yorum Ekle
  3. Shark Pet Perfect II Battery Replacement: adım 3, 3 resimden 1. Shark Pet Perfect II Battery Replacement: adım 3, 3 resimden 2. Shark Pet Perfect II Battery Replacement: adım 3, 3 resimden 3.
    • Pull the battery out of the compartment.
    • Carefully disconnect the quick disconnect couplers.
    • The Couplers may be tightly secured so it may be necessary to use a small flat device to carefully loosen the coupler.
    • Be sure to use an ESD safe tool like the nylon spudger when working with wires and batteries—this will prevent injury and/or device damage.
    FixBot'a Sor
    Yorum Ekle
  4. Shark Pet Perfect II Battery Replacement: adım 4, 1 resimden 1.
    • Completely remove the old battery from the vacuum .
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Ekli Belgeler
Christine Robles
113 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G5, Liner Summer 2017 UW Tacoma, Team S1-G5, Liner Summer 2017 üyesi
UWT-LINER-SU17S1G5
4 Üyeler
12 adet Kılavuz yazıldı
12Kılavuz Yorumları
Removed the single screw but cover will not come off. What do you do?
Adalyn Etelamaki - Yanıt Paylaş
Just tried it. The cover is a bit hard. Gold the vacuum at an angle and slightly push the notch on the cover with a flat screwdriver, it should come out.
PradSim Promo Ads - Yanıt Paylaş
Will it run on cord only
ligthelf - Yanıt Paylaş
NO. Requires batteries.
Jim DeCamp - Yanıt Paylaş
1.) Mine was much harder to disassemble, took considerable force.
2.) No one sells form, fit and function replacement batteries, including Shark
3.) The available replacement are much smaller in volume, and hence power, and require padding or they will rattle.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 79
Her zaman: 19,931
