Ana içeriğe geç
Shark Pet Perfect II Front Belt Replacement
Neye ihtiyacın var
  1. Shark Pet Perfect II Front Belt Replacement, Front Belt: adım 1, 1 resimden 1.
    • Remove the motorized brush from the dust cup by pulling it apart.
  2. Shark Pet Perfect II Front Belt Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the five 14mm screws from the face of the motorized brush.
  3. Shark Pet Perfect II Front Belt Replacement: adım 3, 2 resimden 1. Shark Pet Perfect II Front Belt Replacement: adım 3, 2 resimden 2.
    • Separate the motorized brush face plate by using a flat prying tool.
  4. Shark Pet Perfect II Front Belt Replacement: adım 4, 3 resimden 1. Shark Pet Perfect II Front Belt Replacement: adım 4, 3 resimden 2. Shark Pet Perfect II Front Belt Replacement: adım 4, 3 resimden 3.
    • Remove the brush roller by lifting vertically away from the brush head. It should come out easily along with the belt.
    • Be careful in handling the belt. If stretched or damaged, the belt can cause the motorized brush to operate incorrectly.
Sonuç
Ekli Belgeler
Tanner Brown
459 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G5, Liner Summer 2017 UW Tacoma, Team S1-G5, Liner Summer 2017 üyesi
UWT-LINER-SU17S1G5
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Thank you for this! I needed the picture to put it back together after I cleaned it out because it was not spinning. Working perfectly now! I also have an extra new battery if anyone needs it. :)
Aaron Woods - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 9
Her zaman: 780
