Ana içeriğe geç
Giriş
Removing the water tank will require removing the front panel and opening the mop body. Once accessible though, replacement is quite simple. Before doing any disassembly on your Shark Professional Steam Pocket Mop, make sure to unplug the mop and empty the water tank for your safety.
  1. Unwrap the power cord from the handle. Remove the 56.0 mm Phillips head #2 screw located above the water tank cap.
    • Unwrap the power cord from the handle.
    • Remove the 56.0 mm Phillips head #2 screw located above the water tank cap.
    • Pull the handle to separate it from the body.
  2. Remove the three 12.0 mm Phillips head #2 screws where the handle connects to the body. Remove the plastic cap. Remove the plastic cap.
    • Remove the three 12.0 mm Phillips head #2 screws where the handle connects to the body.
    • Remove the plastic cap.
  3. Remove the three 16.0 mm T10 Torx screws near the top of the body and remove the water tank cap. The third screw is directly on other side of the bottom screw in the photo.
    • Remove the three 16.0 mm T10 Torx screws near the top of the body and remove the water tank cap.
    • The third screw is directly on other side of the bottom screw in the photo.
  4. Remove steam control button cover with a metal spudger. Remove the two 12.0 mm Phillips head #2 screws underneath. Remove the plastic rim with clear plastic cover.
    • Remove steam control button cover with a metal spudger.
    • Remove the two 12.0 mm Phillips head #2 screws underneath.
    • Remove the plastic rim with clear plastic cover.
  5. Remove the Shark logo decal on the front of body using a metal spudger. Remove the two 12.0 mm Phillips head #2 screws underneath. Pull out the plastic cover to remove.
    • Remove the Shark logo decal on the front of body using a metal spudger.
    • Pull out the plastic cover to remove.
  6. Pop off the grey front plate to expose the control panel and screws necessary to open mop body.
    • Pop off the grey front plate to expose the control panel and screws necessary to open mop body.
  7. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  8. Remove the three 12.0 mm Philips head #2 screws connected to the dark grey plastic trim.
    • Remove the three 12.0 mm Philips head #2 screws connected to the dark grey plastic trim.
  9. Remove the four 16.0 mm T10 Torx screws located on the back of the mop.
    • Remove the four 16.0 mm T10 Torx screws located on the back of the mop.
  10. Remove the two 12.0 mm Phillips head #2 screws that hold the power cord to the device.
    • Remove the two 12.0 mm Phillips head #2 screws that hold the power cord to the device.
  11. Pop off the dark grey plastic trim cover.
    • Pop off the dark grey plastic trim cover.
  12. Pop open the white plastic mop body by pulling apart from the front and back side.
    • Pop open the white plastic mop body by pulling apart from the front and back side.
  13. Remove the top left 12.0 mm Phillips head #2 screw from inside body. Remove the top left 12.0 mm Phillips head #2 screw from inside body.
    • Remove the top left 12.0 mm Phillips head #2 screw from inside body.
  14. Remove four 12.0 mm Phillips head #2 screws from the inside of the mop body. Remove four 12.0 mm Phillips head #2 screws from the inside of the mop body.
    • Remove four 12.0 mm Phillips head #2 screws from the inside of the mop body.
  15. Pull apart the bottom of the mop body from the dark grey connector. Disconnect the tube from the bottom
    • Pull apart the bottom of the mop body from the dark grey connector.
    • Disconnect the tube from the bottom
  16. Remove two 12.0 mm Phillips head #2 screws on the top and then pull back the black foam to reveal and remove the third 12.0 mm Phillips head #2 screw. Remove two 12.0 mm Phillips head #2 screws on the top and then pull back the black foam to reveal and remove the third 12.0 mm Phillips head #2 screw.
    • Remove two 12.0 mm Phillips head #2 screws on the top and then pull back the black foam to reveal and remove the third 12.0 mm Phillips head #2 screw.
  17. Pull apart the mop body from the water tank to separate.
    • Pull apart the mop body from the water tank to separate.
Sonuç
Brett Wilson
848 İtibar
6 adet Kılavuz yazıldı
Takım
USF Tampa, Team S15-G1, Boczar Spring 2018 USF Tampa, Team S15-G1, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S15G1
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 5
Son 30 Gün: 17
Her zaman: 175
