Ana içeriğe geç
Shark Rocket HV301 Filter Replacement
Neye ihtiyacın var
    1. Shark Rocket HV301 Filter Replacement, Filter: adım 1, 3 resimden 1. Shark Rocket HV301 Filter Replacement, Filter: adım 1, 3 resimden 2. Shark Rocket HV301 Filter Replacement, Filter: adım 1, 3 resimden 3.
      • Locate the orange filter lid on the front of the vacuum.
      • Remove the orange filter lid by pulling on the tab that has "Clean Filter Monthly" written on it.
      FixBot'a Sor
      Yorum Ekle
    2. Shark Rocket HV301 Filter Replacement: adım 2, 3 resimden 1. Shark Rocket HV301 Filter Replacement: adım 2, 3 resimden 2. Shark Rocket HV301 Filter Replacement: adım 2, 3 resimden 3.
      • Remove the the outer and inner filters inside the vacuum by pulling them out.
      FixBot'a Sor
      Yorum Ekle
    3. Shark Rocket HV301 Filter Replacement: adım 3, 3 resimden 1. Shark Rocket HV301 Filter Replacement: adım 3, 3 resimden 2. Shark Rocket HV301 Filter Replacement: adım 3, 3 resimden 3.
      • Wash the filters by running tap water through them until clear unless you are buying new filters.
      • Lay thee filters out until they are completely dry.
      FixBot'a Sor
      Yorum Ekle
    4. Shark Rocket HV301 Filter Replacement: adım 4, 3 resimden 1. Shark Rocket HV301 Filter Replacement: adım 4, 3 resimden 2. Shark Rocket HV301 Filter Replacement: adım 4, 3 resimden 3.
      • Locate the motor filter lid on the top of the vacuum with the vacuum facing you.
      • Remove the motor filter lid by pushing the release clip on the top and pulling towards you.
      FixBot'a Sor
      Yorum Ekle
    5. Shark Rocket HV301 Filter Replacement: adım 5, 2 resimden 1. Shark Rocket HV301 Filter Replacement: adım 5, 2 resimden 2.
      • Pinch the tab on the motor filter to remove it from the vacuum.
      FixBot'a Sor
      Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Christian
478 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-5, Livingston Fall 2016 Cal Poly, Team 10-5, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S10G5
4 Üyeler
36 adet Kılavuz yazıldı
12Kılavuz Yorumları
great! I had an extra filter in a package of filters I bought and couldn't for the life of me figure there that one on top of the motor went. I haven't changed it since I bought the cleaner 2 years ago!
randy thill - Yanıt Paylaş
My motor filter is now almost completely black. Is that normal?
chanel a - Yanıt Paylaş
Nope. If it’s cloth, wash it with soap and water, toss it in the drier, and put it back in. If it’s washable but not cloth, wash it, let it dry - good to go
Robin Wenz - Yanıt Paylaş
Am I missing something? Isn’t the conclusion a little premature? The filter in the back, are we able to clean it or not? A couple of YouTube videos on the subject say not to clean this filter. When my vacuum is under load and they close off the suction I immediately have a loss of suction power and loud suction noise out the back. Basically it is losing almost all the suction power out the back when the vacuum is under load. This happens regardless if I have the filter in or out so I can’t imagine cleaning it will make much difference. I have cleaned all my other filters. Other than that the vacuum sounds like it’s working well. I can’t find any other information on the topic. This is not happen to anyone else? Thank you for any help and also if you could clarify if we can clean the filter in the back or not as well that would be great. My apologies if this was already mentioned somewhere in the video earlier on. May want to include it at the end when discussing that particular filter anyways?
Bilbo - Yanıt Paylaş
Can I rinse the motor filter?
Ashley Stilabower - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 57
Son 30 gün: 259
Her zaman: 55,370
