Ana içeriğe geç
Shark Rocket HV301 Rotary Belt Replacement
Neye ihtiyacın var
    1. Shark Rocket HV301 Rotary Belt Replacement, Rotary Brush: adım 1, 3 resimden 1. Shark Rocket HV301 Rotary Belt Replacement, Rotary Brush: adım 1, 3 resimden 2. Shark Rocket HV301 Rotary Belt Replacement, Rotary Brush: adım 1, 3 resimden 3.
      • Flip the vacuum so the bottom base is visible.
      • Gently pry the bottom two wheels off with a plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    2. Shark Rocket HV301 Rotary Belt Replacement: adım 2, 3 resimden 1. Shark Rocket HV301 Rotary Belt Replacement: adım 2, 3 resimden 2. Shark Rocket HV301 Rotary Belt Replacement: adım 2, 3 resimden 3.
      • Remove five visible screws with a Phillips #2 screwdriver.
      • Locate and twist the three plastic screws to the unlock position with a quarter or flathead screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Shark Rocket HV301 Rotary Belt Replacement: adım 3, 3 resimden 1. Shark Rocket HV301 Rotary Belt Replacement: adım 3, 3 resimden 2. Shark Rocket HV301 Rotary Belt Replacement: adım 3, 3 resimden 3.
      • Remove plate covering the roller brush.
      FixBot'a Sor
      Yorum Ekle
    4. Shark Rocket HV301 Rotary Belt Replacement: adım 4, 2 resimden 1. Shark Rocket HV301 Rotary Belt Replacement: adım 4, 2 resimden 2.
      • Use a Phillips #2 screwdriver to extract the three screws revealed from removing the plate.
      FixBot'a Sor
      Yorum Ekle
    5. Shark Rocket HV301 Rotary Belt Replacement: adım 5, 3 resimden 1. Shark Rocket HV301 Rotary Belt Replacement: adım 5, 3 resimden 2. Shark Rocket HV301 Rotary Belt Replacement: adım 5, 3 resimden 3.
      • Turn the vacuum over so the rotary brush is on the ground.
      • Grab the vacuum on both sides of the hose and pull up to remove the top of the vacuum halfway.
      FixBot'a Sor
      Yorum Ekle
    6. Shark Rocket HV301 Rotary Belt Replacement: adım 6, 2 resimden 1. Shark Rocket HV301 Rotary Belt Replacement: adım 6, 2 resimden 2.
      • Gently pinch the head of the cable and pull upwards until the casing disconnects from the vacuum.
      • Proceed with removing the upper casing.
      FixBot'a Sor
      Yorum Ekle
    7. Shark Rocket HV301 Rotary Belt Replacement: adım 7, 2 resimden 1. Shark Rocket HV301 Rotary Belt Replacement: adım 7, 2 resimden 2.
      • Use a Phillips #2 screwdriver to remove the four visible screws securing the rotary brush to the vacuum.
      FixBot'a Sor
      Yorum Ekle
    8. Shark Rocket HV301 Rotary Belt Replacement: adım 8, 3 resimden 1. Shark Rocket HV301 Rotary Belt Replacement: adım 8, 3 resimden 2. Shark Rocket HV301 Rotary Belt Replacement: adım 8, 3 resimden 3.
      • Remove the rotary belt on right side of vacuum from the bearing.
      • Gently lift the casing to remove the belt and brush from the vacuum.
      FixBot'a Sor
      Yorum Ekle
    9. Shark Rocket HV301 Rotary Belt Replacement: adım 9, 3 resimden 1. Shark Rocket HV301 Rotary Belt Replacement: adım 9, 3 resimden 2. Shark Rocket HV301 Rotary Belt Replacement: adım 9, 3 resimden 3.
      • Gently pry off the plastic casing on both sides of rotary brush.
      • Lift the clear plastic shell from the rotary brush.
      FixBot'a Sor
      Yorum Ekle
    10. Shark Rocket HV301 Rotary Belt Replacement: adım 10, 1 resimden 1.
      • Remove the rotary belt attached to the brush and replace it if needed.
      FixBot'a Sor
      Yorum Ekle
    1. Shark Rocket HV301 Rotary Belt Replacement, Rotary Belt: adım 11, 1 resimden 1.
      • Replace belt if torn or damaged.
      FixBot'a Sor
      Yorum Ekle
Sonuç
18 farklı kişi bu kılavuzu tamamladı.
Trey Nahhas
848 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-5, Livingston Fall 2016 Cal Poly, Team 10-5, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S10G5
4 Üyeler
20 adet Kılavuz yazıldı
4Kılavuz Yorumları
Where can I find the rotary belt for the Shark Duo?
oneupchallenges - Yanıt Paylaş
I could not get it out without removing the brush roll motor. So I am putting it back together and I need to know if the motor has a top and bottom. What I mean is does it matter ? Thank you
Jennifer Dalton - Yanıt Paylaş
Thanks for the guide it came in super handy
SYSTEM 855 - Yanıt Paylaş
I just wish there were instructions on how to put the vacuum cleaner back together. I have memory issues and have a hard time going in reverse when I look at the dissembly process.
The Instructions were on the spot and even someone like me was able to disassemble the Shark Rocket.
Now to figure out how to reassemble it.
Thank you,
John
John Bartkowski - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 42
Son 30 gün: 181
Her zaman: 38,120
