Ana içeriğe geç
Shark Rocket HV301 Rotary Belt Replacement
Neye ihtiyacın var
  1. Shark Rocket HV301 Rotary Belt Replacement, Rotary Brush: adım 1, 3 resimden 1. Shark Rocket HV301 Rotary Belt Replacement, Rotary Brush: adım 1, 3 resimden 2. Shark Rocket HV301 Rotary Belt Replacement, Rotary Brush: adım 1, 3 resimden 3.
    • Flip the vacuum so the bottom base is visible.
    • Gently pry the bottom two wheels off with a plastic opening tool.
  2. Shark Rocket HV301 Rotary Belt Replacement: adım 2, 3 resimden 1. Shark Rocket HV301 Rotary Belt Replacement: adım 2, 3 resimden 2. Shark Rocket HV301 Rotary Belt Replacement: adım 2, 3 resimden 3.
    • Remove five visible screws with a Phillips #2 screwdriver.
    • Locate and twist the three plastic screws to the unlock position with a quarter or flathead screwdriver.
  3. Shark Rocket HV301 Rotary Belt Replacement: adım 3, 3 resimden 1. Shark Rocket HV301 Rotary Belt Replacement: adım 3, 3 resimden 2. Shark Rocket HV301 Rotary Belt Replacement: adım 3, 3 resimden 3.
    • Remove plate covering the roller brush.
  4. Shark Rocket HV301 Rotary Belt Replacement: adım 4, 2 resimden 1. Shark Rocket HV301 Rotary Belt Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #2 screwdriver to extract the three screws revealed from removing the plate.
  5. Shark Rocket HV301 Rotary Belt Replacement: adım 5, 3 resimden 1. Shark Rocket HV301 Rotary Belt Replacement: adım 5, 3 resimden 2. Shark Rocket HV301 Rotary Belt Replacement: adım 5, 3 resimden 3.
    • Turn the vacuum over so the rotary brush is on the ground.
    • Grab the vacuum on both sides of the hose and pull up to remove the top of the vacuum halfway.
  6. Shark Rocket HV301 Rotary Belt Replacement: adım 6, 2 resimden 1. Shark Rocket HV301 Rotary Belt Replacement: adım 6, 2 resimden 2.
    • Gently pinch the head of the cable and pull upwards until the casing disconnects from the vacuum.
    • Proceed with removing the upper casing.
  7. Shark Rocket HV301 Rotary Belt Replacement: adım 7, 2 resimden 1. Shark Rocket HV301 Rotary Belt Replacement: adım 7, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the four visible screws securing the rotary brush to the vacuum.
  8. Shark Rocket HV301 Rotary Belt Replacement: adım 8, 3 resimden 1. Shark Rocket HV301 Rotary Belt Replacement: adım 8, 3 resimden 2. Shark Rocket HV301 Rotary Belt Replacement: adım 8, 3 resimden 3.
    • Remove the rotary belt on right side of vacuum from the bearing.
    • Gently lift the casing to remove the belt and brush from the vacuum.
  9. Shark Rocket HV301 Rotary Belt Replacement: adım 9, 3 resimden 1. Shark Rocket HV301 Rotary Belt Replacement: adım 9, 3 resimden 2. Shark Rocket HV301 Rotary Belt Replacement: adım 9, 3 resimden 3.
    • Gently pry off the plastic casing on both sides of rotary brush.
    • Lift the clear plastic shell from the rotary brush.
  10. Shark Rocket HV301 Rotary Belt Replacement: adım 10, 1 resimden 1.
    • Remove the rotary belt attached to the brush and replace it if needed.
  11. Shark Rocket HV301 Rotary Belt Replacement, Rotary Belt: adım 11, 1 resimden 1.
    • Replace belt if torn or damaged.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Trey Nahhas
779 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-5, Livingston Fall 2016 Cal Poly, Team 10-5, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S10G5
4 Üyeler
14 adet Kılavuz yazıldı
3 Yorum
Where can I find the rotary belt for the Shark Duo?
oneupchallenges - Yanıt
I could not get it out without removing the brush roll motor. So I am putting it back together and I need to know if the motor has a top and bottom. What I mean is does it matter ? Thank you
Jennifer Dalton - Yanıt
Thanks for the guide it came in super handy
SYSTEM 855 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 53
Son 30 gün: 194
Her zaman: 33,455
