Ana içeriğe geç
Shark Rocket HV301 Rotary Brush Replacement
Neye ihtiyacın var
  1. Shark Rocket HV301 Rotary Brush Replacement, Rotary Brush: adım 1, 3 resimden 1. Shark Rocket HV301 Rotary Brush Replacement, Rotary Brush: adım 1, 3 resimden 2. Shark Rocket HV301 Rotary Brush Replacement, Rotary Brush: adım 1, 3 resimden 3.
    • Flip the vacuum so the bottom base is visible.
    • Gently pry the bottom two wheels off with a plastic opening tool.
  2. Shark Rocket HV301 Rotary Brush Replacement: adım 2, 3 resimden 1. Shark Rocket HV301 Rotary Brush Replacement: adım 2, 3 resimden 2. Shark Rocket HV301 Rotary Brush Replacement: adım 2, 3 resimden 3.
    • Remove five visible screws with a Phillips #2 screwdriver.
    • Locate and twist the three plastic screws to the unlock position with a quarter or flathead screwdriver.
  3. Shark Rocket HV301 Rotary Brush Replacement: adım 3, 3 resimden 1. Shark Rocket HV301 Rotary Brush Replacement: adım 3, 3 resimden 2. Shark Rocket HV301 Rotary Brush Replacement: adım 3, 3 resimden 3.
    • Remove plate covering the roller brush.
  4. Shark Rocket HV301 Rotary Brush Replacement: adım 4, 2 resimden 1. Shark Rocket HV301 Rotary Brush Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #2 screwdriver to extract the three screws revealed from removing the plate.
  5. Shark Rocket HV301 Rotary Brush Replacement: adım 5, 3 resimden 1. Shark Rocket HV301 Rotary Brush Replacement: adım 5, 3 resimden 2. Shark Rocket HV301 Rotary Brush Replacement: adım 5, 3 resimden 3.
    • Turn the vacuum over so the rotary brush is on the ground.
    • Grab the vacuum on both sides of the hose and pull up to remove the top of the vacuum halfway.
  6. Shark Rocket HV301 Rotary Brush Replacement: adım 6, 2 resimden 1. Shark Rocket HV301 Rotary Brush Replacement: adım 6, 2 resimden 2.
    • Gently pinch the head of the cable and pull upwards until the casing disconnects from the vacuum.
    • Proceed with removing the upper casing.
  7. Shark Rocket HV301 Rotary Brush Replacement: adım 7, 2 resimden 1. Shark Rocket HV301 Rotary Brush Replacement: adım 7, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the four visible screws securing the rotary brush to the vacuum.
  8. Shark Rocket HV301 Rotary Brush Replacement: adım 8, 3 resimden 1. Shark Rocket HV301 Rotary Brush Replacement: adım 8, 3 resimden 2. Shark Rocket HV301 Rotary Brush Replacement: adım 8, 3 resimden 3.
    • Remove the rotary belt on right side of vacuum from the bearing.
    • Gently lift the casing to remove the belt and brush from the vacuum.
  9. Shark Rocket HV301 Rotary Brush Replacement: adım 9, 3 resimden 1. Shark Rocket HV301 Rotary Brush Replacement: adım 9, 3 resimden 2. Shark Rocket HV301 Rotary Brush Replacement: adım 9, 3 resimden 3.
    • Gently pry off the plastic casing on both sides of rotary brush.
    • Lift the clear plastic shell from the rotary brush.
  10. Shark Rocket HV301 Rotary Brush Replacement: adım 10, 1 resimden 1.
    • Remove the rotary belt attached to the brush and replace it if needed.
Sonuç
21 farklı kişi bu kılavuzu tamamladı.
Jonathan Baruch
796 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-5, Livingston Fall 2016 Cal Poly, Team 10-5, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S10G5
4 Üyeler
14 adet Kılavuz yazıldı
29 Yorum
This is a well written and very informative tutorial. Thank you for your time and effort. However, I am finding it difficult to locate a new rotary brush for my Shark Rocket model HV301. At best, I’ve been told that the rotary brushes available ‘May fit’ my vacuum. Hardly a resounding voice of confidence when ordering a replacement part. Does anyone know the part number or ordering information regarding the Shark Rocket model HV301 rotary brush? Thank you for your time.
TCP - Yanıt
I also need a new brush did you find out where to get one and could you pass it on to me thank you
Jeffro -
Hi, I'm also having a hard time trying to find the rotary brush roll, does anyone have any suggestions where I can find & purchase it?
Rosalina Padilla -
Try Amazon.com there are several parts for shark vacuum, just make sure to have the model number in hand. I hope this help.
Thanks!
Andres B -
I want to give this author 30 points only because that seems to be the maximum. Excellent work; thank you very much.
Larry - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 106
Son 30 gün: 601
Her zaman: 56,058
