Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Flip the vacuum so the bottom base is visible.
Gently pry the bottom two wheels off with a plastic opening tool.
Remove five visible screws with a Phillips #2 screwdriver.
Locate and twist the three plastic screws to the unlock position with a quarter or flathead screwdriver.
Use a Phillips #2 screwdriver to extract the three screws revealed from removing the plate.
Turn the vacuum over so the rotary brush is on the ground.
Grab the vacuum on both sides of the hose and pull up to remove the top of the vacuum halfway.
Gently pinch the head of the cable and pull upwards until the casing disconnects from the vacuum.
Proceed with removing the upper casing.
Use a Phillips #2 screwdriver to remove the four visible screws securing the rotary brush to the vacuum.
Remove the rotary belt on right side of vacuum from the bearing.
Gently lift the casing to remove the belt and brush from the vacuum.
Gently pry off the plastic casing on both sides of rotary brush.
Lift the clear plastic shell from the rotary brush.
Remove the rotary belt attached to the brush and replace it if needed.
21 farklı kişi bu kılavuzu tamamladı.
29 Yorum
This is a well written and very informative tutorial. Thank you for your time and effort. However, I am finding it difficult to locate a new rotary brush for my Shark Rocket model HV301. At best, I’ve been told that the rotary brushes available ‘May fit’ my vacuum. Hardly a resounding voice of confidence when ordering a replacement part. Does anyone know the part number or ordering information regarding the Shark Rocket model HV301 rotary brush? Thank you for your time.
I also need a new brush did you find out where to get one and could you pass it on to me thank you
Jeffro -
Hi, I'm also having a hard time trying to find the rotary brush roll, does anyone have any suggestions where I can find & purchase it?
Try Amazon.com there are several parts for shark vacuum, just make sure to have the model number in hand. I hope this help.
Thanks!
Andres B -
