Ana içeriğe geç
Shark Rocket Powerhead AH401 Belt Replacement
Neye ihtiyacın var
  1. Shark Rocket Powerhead AH401 Belt Replacement, Brushroll: adım 1, 3 resimden 1. Shark Rocket Powerhead AH401 Belt Replacement, Brushroll: adım 1, 3 resimden 2. Shark Rocket Powerhead AH401 Belt Replacement, Brushroll: adım 1, 3 resimden 3.
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Belt Replacement: adım 2, 2 resimden 1. Shark Rocket Powerhead AH401 Belt Replacement: adım 2, 2 resimden 2.
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Belt Replacement, Back Panel Screws: adım 3, 2 resimden 1. Shark Rocket Powerhead AH401 Belt Replacement, Back Panel Screws: adım 3, 2 resimden 2.
    • Flip the device over so that the bottom is face up.
    • Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
    • Two 14 mm Torx screws
    • Two 16 mm Torx screws
    • Four 21 mm Torx screws
  4. Shark Rocket Powerhead AH401 Belt Replacement, Filter Grille: adım 4, 2 resimden 1. Shark Rocket Powerhead AH401 Belt Replacement, Filter Grille: adım 4, 2 resimden 2.
    • Push inward on the top of the filter grille where it says "Push."
    • Lift the filter grille upward.
  5. Shark Rocket Powerhead AH401 Belt Replacement: adım 5, 2 resimden 1. Shark Rocket Powerhead AH401 Belt Replacement: adım 5, 2 resimden 2.
    • Lift gently and pull the grille up towards you until it releases.
    • The post-motor filter is underneath the filter grille.
  6. Shark Rocket Powerhead AH401 Belt Replacement, Belt: adım 6, 1 resimden 1.
    • Remove the four screws by rotating counter-clockwise:
    • One 12 mm screw with a T10 Torx screwdriver
    • Three 14 mm screw with a T15 Torx screwdriver
  7. Shark Rocket Powerhead AH401 Belt Replacement: adım 7, 3 resimden 1. Shark Rocket Powerhead AH401 Belt Replacement: adım 7, 3 resimden 2. Shark Rocket Powerhead AH401 Belt Replacement: adım 7, 3 resimden 3.
    • Remove the grey filter plate by simply lifting upward.
    • Remove the 14mm screw by rotating counter clockwise with a T10 Torx screwdriver.
  8. Shark Rocket Powerhead AH401 Belt Replacement: adım 8, 1 resimden 1.
    • Remove three 10mm screws by rotating counter-clockwise with a T15 Torx screwdriver.
  9. Shark Rocket Powerhead AH401 Belt Replacement: adım 9, 2 resimden 1. Shark Rocket Powerhead AH401 Belt Replacement: adım 9, 2 resimden 2.
    • Remove the airpath grille from the side of the motor compartment by pulling out and away from the attached area.
  10. Shark Rocket Powerhead AH401 Belt Replacement: adım 10, 2 resimden 1. Shark Rocket Powerhead AH401 Belt Replacement: adım 10, 2 resimden 2.
    • Remove the motor compartment panel by lifting up and away from the device.
  11. Shark Rocket Powerhead AH401 Belt Replacement: adım 11, 2 resimden 1. Shark Rocket Powerhead AH401 Belt Replacement: adım 11, 2 resimden 2.
    • Remove one 14mm screw by rotating counter-clockwise with a T15 Torx screwdriver.
  12. Shark Rocket Powerhead AH401 Belt Replacement: adım 12, 2 resimden 1. Shark Rocket Powerhead AH401 Belt Replacement: adım 12, 2 resimden 2.
    • Disconnect the motor side panel by lifting the motor and panel up and out.
    • This step may require some wiggling to loosen the panel before it becomes free.
  13. Shark Rocket Powerhead AH401 Belt Replacement: adım 13, 1 resimden 1.
    • Remove one 9mm screw by rotating counter-clockwise with a Phillips #2 screwdriver.
    • This screw allows the side panel to be removed.
  14. Shark Rocket Powerhead AH401 Belt Replacement: adım 14, 2 resimden 1. Shark Rocket Powerhead AH401 Belt Replacement: adım 14, 2 resimden 2.
    • Remove the side panel by pulling the panel out and away from the motor.
    • The side panel is connected with clips which connect near the brushroll axle.
  15. Shark Rocket Powerhead AH401 Belt Replacement: adım 15, 2 resimden 1. Shark Rocket Powerhead AH401 Belt Replacement: adım 15, 2 resimden 2.
    • Loosen the two screws by rotating counter clockwise with a T15 Torx screwdriver.
    • The screws only need to be loosened in order to free the belt.
  16. Shark Rocket Powerhead AH401 Belt Replacement: adım 16, 2 resimden 1. Shark Rocket Powerhead AH401 Belt Replacement: adım 16, 2 resimden 2.
    • Remove the belt by pulling the belt away from the axle.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Shobhit Dabral
913 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G3, Livingston Winter 2018 Cal Poly, Team S19-G3, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S19G3
4 Üyeler
18 adet Kılavuz yazıldı
15 Yorum
These instructions were fantastic accept for one section. On Step 9 you never mention to first remove the Motor Compartment Panel before removing the airpath grille. The picture just shows the panel already removed. Otherwise, I followed the directions forwards and backwards and I was successful!! I went to the local vacuum repair store to purchase a new belt. They did not have the Shark belt so I purchased the Bissell BIBL, BELT geared 80R4, 47A2 for $3.50 and it worked perfectly!!
Liz Needham - Yanıt
there is a hidden screw on the outside of the compartment/ motor side where the handle mets the motor compartment panel / in the corner iif i could leave a pic i would.
nm1hart -
is the Shark 400 and 401 the same in changing the dive belt?
Alfonso Luna - Yanıt
What is the replacement belt part#? Did I miss that somewhere here? I can’t find it on their web site or anywhere else on line using the AH401 model #, thanks
Mark Pugliese - Yanıt
I have an AH452 and the belt number is 4315 SC or Gates # 192-3GT6-SAR
Walt Shuler -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 30
Son 30 gün: 94
Her zaman: 14,627
