Ana içeriğe geç
Shark Rocket Powerhead AH401 Brushroll Cap Replacement
  1. Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll: adım 1, 3 resimden 1. Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll: adım 1, 3 resimden 2. Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll: adım 1, 3 resimden 3.
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Brushroll Cap Replacement: adım 2, 2 resimden 1. Shark Rocket Powerhead AH401 Brushroll Cap Replacement: adım 2, 2 resimden 2.
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll Cap: adım 3, 3 resimden 1. Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll Cap: adım 3, 3 resimden 2. Shark Rocket Powerhead AH401 Brushroll Cap Replacement, Brushroll Cap: adım 3, 3 resimden 3.
    • Remove the cap by pushing the "pull" tab.
Sonuç
Shobhit Dabral
913 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G3, Livingston Winter 2018 Cal Poly, Team S19-G3, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S19G3
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 17
Her zaman: 960
