Ana içeriğe geç
Shark Rocket Powerhead AH401 Filter Grille Replacement
Neye ihtiyacın var
  1. Shark Rocket Powerhead AH401 Filter Grille Replacement, Dust Cup: adım 1, 3 resimden 1. Shark Rocket Powerhead AH401 Filter Grille Replacement, Dust Cup: adım 1, 3 resimden 2. Shark Rocket Powerhead AH401 Filter Grille Replacement, Dust Cup: adım 1, 3 resimden 3.
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Push down on the dust can lever to release the dust can in order to get to the filter grill.
  2. Shark Rocket Powerhead AH401 Filter Grille Replacement: adım 2, 2 resimden 1. Shark Rocket Powerhead AH401 Filter Grille Replacement: adım 2, 2 resimden 2.
    • Remove the dust cup by lifting it off the dock.
  3. Shark Rocket Powerhead AH401 Filter Grille Replacement, Filter Grille: adım 3, 2 resimden 1. Shark Rocket Powerhead AH401 Filter Grille Replacement, Filter Grille: adım 3, 2 resimden 2.
    • Push inward on the top of the filter grille where it says "Push."
    • Lift the filter grille upward.
  4. Shark Rocket Powerhead AH401 Filter Grille Replacement: adım 4, 2 resimden 1. Shark Rocket Powerhead AH401 Filter Grille Replacement: adım 4, 2 resimden 2.
    • Lift gently and pull the grille up towards you until it releases.
    • The post-motor filter is underneath the filter grille.
Sonuç
Shobhit Dabral
913 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G3, Livingston Winter 2018 Cal Poly, Team S19-G3, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S19G3
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 317
