Ana içeriğe geç
Shark Rocket Powerhead AH401 Motherboard Replacement
Neye ihtiyacın var
  1. Shark Rocket Powerhead AH401 Motherboard Replacement, Brushroll: adım 1, 3 resimden 1. Shark Rocket Powerhead AH401 Motherboard Replacement, Brushroll: adım 1, 3 resimden 2. Shark Rocket Powerhead AH401 Motherboard Replacement, Brushroll: adım 1, 3 resimden 3.
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Motherboard Replacement: adım 2, 2 resimden 1. Shark Rocket Powerhead AH401 Motherboard Replacement: adım 2, 2 resimden 2.
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Motherboard Replacement, Dust Cup: adım 3, 3 resimden 1. Shark Rocket Powerhead AH401 Motherboard Replacement, Dust Cup: adım 3, 3 resimden 2. Shark Rocket Powerhead AH401 Motherboard Replacement, Dust Cup: adım 3, 3 resimden 3.
    • Push down on the dust can lever to release the dust can in order to get to the filter grill.
  4. Shark Rocket Powerhead AH401 Motherboard Replacement: adım 4, 2 resimden 1. Shark Rocket Powerhead AH401 Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the dust cup by lifting it off the dock.
  5. Shark Rocket Powerhead AH401 Motherboard Replacement, Back Panel Screws: adım 5, 2 resimden 1. Shark Rocket Powerhead AH401 Motherboard Replacement, Back Panel Screws: adım 5, 2 resimden 2.
    • Flip the device over so that the bottom is face up.
    • Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
    • Two 14 mm Torx screws
    • Two 16 mm Torx screws
    • Four 21 mm Torx screws
  6. Shark Rocket Powerhead AH401 Motherboard Replacement, Motherboard: adım 6, 3 resimden 1. Shark Rocket Powerhead AH401 Motherboard Replacement, Motherboard: adım 6, 3 resimden 2. Shark Rocket Powerhead AH401 Motherboard Replacement, Motherboard: adım 6, 3 resimden 3.
    • Remove the three 10mm screws by rotating counter clockwise with a T15 Torx screwdriver.
    • Remove the airpath grille by gently lifting up and away from the motor compartment.
  7. Shark Rocket Powerhead AH401 Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove two 14mm screws by rotating counter-clockwise with a T15 Torx screwdriver.
  8. Shark Rocket Powerhead AH401 Motherboard Replacement: adım 8, 3 resimden 1. Shark Rocket Powerhead AH401 Motherboard Replacement: adım 8, 3 resimden 2. Shark Rocket Powerhead AH401 Motherboard Replacement: adım 8, 3 resimden 3.
    • Lift and gently remove the hinge compartment covering the motherboard.
  9. Shark Rocket Powerhead AH401 Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove the two 10mm screws by rotating counter-clockwise with a T10 Torx screwdriver
  10. Shark Rocket Powerhead AH401 Motherboard Replacement: adım 10, 2 resimden 1. Shark Rocket Powerhead AH401 Motherboard Replacement: adım 10, 2 resimden 2.
    • Lift the motherboard out of its compartment.
  11. Shark Rocket Powerhead AH401 Motherboard Replacement: adım 11, 3 resimden 1. Shark Rocket Powerhead AH401 Motherboard Replacement: adım 11, 3 resimden 2. Shark Rocket Powerhead AH401 Motherboard Replacement: adım 11, 3 resimden 3.
    • Locate and remove these connections by pulling the plugs out of the sockets.
  12. Shark Rocket Powerhead AH401 Motherboard Replacement: adım 12, 3 resimden 1. Shark Rocket Powerhead AH401 Motherboard Replacement: adım 12, 3 resimden 2. Shark Rocket Powerhead AH401 Motherboard Replacement: adım 12, 3 resimden 3.
    • Flip the motherboard over to reveal the wires underneath.
    • Locate and cut all the wires connected to the motherboard using cutting pliers.
Sonuç
Shobhit Dabral
913 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G3, Livingston Winter 2018 Cal Poly, Team S19-G3, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S19G3
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 526
