Ana içeriğe geç
Shark Rocket Powerhead AH401 Panel Screws Replacement
Neye ihtiyacın var
  1. Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: adım 1, 3 resimden 1. Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: adım 1, 3 resimden 2. Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: adım 1, 3 resimden 3.
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Panel Screws Replacement: adım 2, 2 resimden 1. Shark Rocket Powerhead AH401 Panel Screws Replacement: adım 2, 2 resimden 2.
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: adım 3, 3 resimden 1. Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: adım 3, 3 resimden 2. Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: adım 3, 3 resimden 3.
    • Push down on the dust can lever to release the dust can in order to get to the filter grill.
  4. Shark Rocket Powerhead AH401 Panel Screws Replacement: adım 4, 2 resimden 1. Shark Rocket Powerhead AH401 Panel Screws Replacement: adım 4, 2 resimden 2.
    • Remove the dust cup by lifting it off the dock.
  5. Shark Rocket Powerhead AH401 Panel Screws Replacement, Back Panel Screws: adım 5, 2 resimden 1. Shark Rocket Powerhead AH401 Panel Screws Replacement, Back Panel Screws: adım 5, 2 resimden 2.
    • Flip the device over so that the bottom is face up.
    • Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
    • Two 14 mm Torx screws
    • Two 16 mm Torx screws
    • Four 21 mm Torx screws
Sonuç
Toan Pham
269 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G3, Livingston Winter 2018 Cal Poly, Team S19-G3, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S19G3
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 967
