Ana içeriğe geç
Shark Rocket Professional Floor Hose Replacement
Neye ihtiyacın var
  1. Shark Rocket Professional Floor Hose Replacement, Floor Hose: adım 1, 2 resimden 1. Shark Rocket Professional Floor Hose Replacement, Floor Hose: adım 1, 2 resimden 2.
    • Look at the side of your vacuum.
    • Identify the button that says "Floor Nozzle."
    • Press this button and remove the main body of the vacuum.
  2. Shark Rocket Professional Floor Hose Replacement: adım 2, 3 resimden 1. Shark Rocket Professional Floor Hose Replacement: adım 2, 3 resimden 2. Shark Rocket Professional Floor Hose Replacement: adım 2, 3 resimden 3.
    • Look at the bottom of the Floor Nozzle.
    • Use a coin to turn the orange locking dials counter-clockwise.
    • If you are unsure, follow the arrows when turning the orange dials because the labeling is confusing.
  3. Shark Rocket Professional Floor Hose Replacement: adım 3, 1 resimden 1.
    • Use your fingers to pull open the panel locked by the orange mechanism.
    • If there is debris stuck in the tube, use a long, thin object to remove it.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brad Iglesia
316 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G6, Livingston Winter 2018 Cal Poly, Team S18-G6, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S18G6
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 38
Her zaman: 4,858
