Ana içeriğe geç
Shark Rocket Professional Hose Replacement
Neye ihtiyacın var
    1. Shark Rocket Professional Hose Replacement, Main Hose: adım 1, 3 resimden 1. Shark Rocket Professional Hose Replacement, Main Hose: adım 1, 3 resimden 2. Shark Rocket Professional Hose Replacement, Main Hose: adım 1, 3 resimden 3.
      • Look at the Shark Rocket Professional's Extension Rod.
      • Identify where the hose connects to the main body of the vacuum.
      • Press the tabs on the sides of the connector to remove the hose.
      • You can use a long, thin object to unclog the hose.
      • If this fixes your problem, then you are finished with this guide.
      FixBot'a Sor
      Yorum Ekle
    2. Shark Rocket Professional Hose Replacement: adım 2, 2 resimden 1. Shark Rocket Professional Hose Replacement: adım 2, 2 resimden 2.
      • Look at the vacuum handle and locate the orange button that says "Handle" with a picture of a lock.
      • Press the button and remove the handle.
      FixBot'a Sor
      Yorum Ekle
    3. Shark Rocket Professional Hose Replacement: adım 3, 2 resimden 1. Shark Rocket Professional Hose Replacement: adım 3, 2 resimden 2.
      • Look at the vacuum handle.
      • Using a T-15 screwdriver, remove the five 15mm screws in the handle by turning them counter-clockwise.
      FixBot'a Sor
      Yorum Ekle
    4. Shark Rocket Professional Hose Replacement: adım 4, 3 resimden 1. Shark Rocket Professional Hose Replacement: adım 4, 3 resimden 2. Shark Rocket Professional Hose Replacement: adım 4, 3 resimden 3.
      • Use a plastic opening tool to pry open the handle.
      • Don't worry if the handle sounds like it is going to break; it takes a lot of force to pull apart.
      • When popping open your handle, the small grey piece of plastic(pictured in the last frame) will fly out.
      FixBot'a Sor
      Yorum Ekle
    5. Shark Rocket Professional Hose Replacement: adım 5, 3 resimden 1. Shark Rocket Professional Hose Replacement: adım 5, 3 resimden 2. Shark Rocket Professional Hose Replacement: adım 5, 3 resimden 3.
      • The orange plastic piece may have naturally fallen out at this point.
      • Look a your handle.
      • Using your hands, pull the tube from the nozzle of the handle.
      • The tube is soldered onto a wire connecting to the plastic orange piece inside the handle.
      • Cut this connection with wire clippers to remove and replace your tube.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brad Iglesia
316 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G6, Livingston Winter 2018 Cal Poly, Team S18-G6, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S18G6
4 Üyeler
15 adet Kılavuz yazıldı
4Kılavuz Yorumları
How about an expla8nation about how t9 actually do the lower the hose inside the brush head
Jonathan Hill - Yanıt Paylaş
How do you replace the hose in the beater head
daveve2 - Yanıt Paylaş
Thank you for this, this guide helped a ton.
Bradlee Johnson - Yanıt Paylaş
How long does it take to answer acquestion?
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 70
Her zaman: 6,951
