Ana içeriğe geç
Shark Rotator Lift-Away Speed Brushroll Replacement
Neye ihtiyacın var
  1. Shark Rotator Lift-Away Speed Brushroll Replacement, Brushroll: adım 1, 1 resimden 1.
    • Make sure the vacuum is turned off and unplugged before proceeding.
    • Locate the release button at the top of the vacuum pod next to the handle.
    • Use the handle to lift the pod up off of the vacuum nozzle while pressing the release button.
    • Removing the pod is optional, but it may be easier to locate blockages or access the motor and belt if you do so.
  2. Shark Rotator Lift-Away Speed Brushroll Replacement: adım 2, 2 resimden 1. Shark Rotator Lift-Away Speed Brushroll Replacement: adım 2, 2 resimden 2.
    • Press the Brushroll Access buttons on the top of the nozzle to reveal the brushroll compartment.
  3. Shark Rotator Lift-Away Speed Brushroll Replacement: adım 3, 2 resimden 1. Shark Rotator Lift-Away Speed Brushroll Replacement: adım 3, 2 resimden 2.
    • Lift the brushroll out by using the pull-tab on the left side.
    • You can test the brushroll once it has been inserted by plugging the vacuum in and running the vacuum in carpet mode. The brushroll indicator light should be a solid green color.
Sonuç
Weston Mongomery
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G7, Livingston Fall 2017 Cal Poly, Team S15-G7, Livingston Fall 2017 üyesi
CPSU-LIVINGSTON-F17S15G7
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 1,809
