Ana içeriğe geç
Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement
  1. Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement, Hose and Wand Attachment: adım 1, 1 resimden 1.
    • Make sure the vacuum is turned off and unplugged before proceeding.
    • Place the vacuum upright and locate the attachment you want removed.
  2. Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: adım 2, 3 resimden 1. Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: adım 2, 3 resimden 2. Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: adım 2, 3 resimden 3.
    • Slide the attachments off of the end of the wand.
    • Some attachments may have a "Release" button--if so, hold down the button while sliding the attachment off.
    • The back of the vacuum has slots to hold up to two vacuum attachments. To store, simply place the attachment onto the circular slots.
  3. Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: adım 3, 2 resimden 1. Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: adım 3, 2 resimden 2.
    • Locate the button that says “Release Wand” and press down.
    • Press button while lifting upwards on the handle at the top of the wand.
  4. Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: adım 4, 2 resimden 1. Shark Rotator Lift-Away Speed Vacuum Hose and Wand Accessory Replacement: adım 4, 2 resimden 2.
    • Locate the black hose on the back of the vacuum.
    • Locate the silver release levers on the top and bottom of the hose.
    • Press on the silver release levers and pull up and away from the device to release the hose.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Samantha Woo
330 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G7, Livingston Fall 2017 Cal Poly, Team S15-G7, Livingston Fall 2017 üyesi
CPSU-LIVINGSTON-F17S15G7
4 Üyeler
10 adet Kılavuz yazıldı
4 Yorum
I cannot figure out how to attach het attachments for my new Shark Rotary 752. They just will not go in.
Sandra Groeninger - Yanıt
I have a shark duoclean Hv3900k and have attached the dusting accessory but I can't get it off after hoovering my staircase
ac002n1397 - Yanıt
A small white plastic ring which attaches the hose to the junction of the rotating part of machine. the model is NV50101, Shark Rotator Professional. Since I can't keep the hose connected to the vacuum, it cannot be used.
Gilda Allen - Yanıt
The small white plastic ring on the bottom of the hose is broken and thus the hose will not lock into place.
Gilda Allen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 22
Son 30 gün: 118
Her zaman: 18,404
