Ana içeriğe geç
Shark Rotator NV502 Foam Filter Replacement
  1. Shark Rotator NV502 Foam Filter Replacement, Foam Filter: adım 1, 1 resimden 1.
    • Locate and press the tab on the top of the removable canister.
    • Lift the canister away from the body of the vacuum.
  2. Shark Rotator NV502 Foam Filter Replacement: adım 2, 1 resimden 1.
    • Look inside the tall hole to locate the foam filter inside.
    • Pull out the foam filter.
  3. Shark Rotator NV502 Foam Filter Replacement: adım 3, 1 resimden 1.
    • Remove the felt filter just below the foam filter
    • Clean or Replace the filters. Let the filter dry before reinserting.
Sonuç
Samuel
307 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-3, Livingston Fall 2016 Cal Poly, Team 4-3, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S4G3
4 Üyeler
19 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 1,927
