Giriş
The Shark Rotator Powered Lift-Away has one rotatory belt. The belt is responsible for the mechanical rotations of the brushroll. Without it, the vacuum will not function. The vacuum's belt is designed to last approximately 7 years. Replacement of the belt is needed to keep the vacuum at optimal working condition. This replacement guide demonstrates how to replace the belt in the vacuum.
Neye ihtiyacın var
Turn the vacuum on its side.
Using a quarter, twist the three green locks to the unlock position.
Pull the bottom roller brush cover to open the vacuum.
2 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Where can we buy belts in UK?
where cn i get a belt for this vaccum
We have the belts courtesy of that place named after a rainforest. This morning I took out enough screws to weigh them in and take a holiday with the reward, couldn't see how to get in so gave up in frustration and replaced all the screws. The usual Google search provides images of the side cover removal via screws but for some reason ours doesn't have any side access. I found this post eventually so will be trying again later when the old blood pressure has returned to acceptable levels. Jeez, that's a lot screws just for a new belt. We love the Shark after years of Dysons, but comparing ease of home servicing leaves a lot to be desired..
