Ana içeriğe geç
Shark Rotator Powered Lift-Away Speed Filter Replacement
  1. Shark Rotator Powered Lift-Away Speed Filter Replacement, Filter: adım 1, 3 resimden 1. Shark Rotator Powered Lift-Away Speed Filter Replacement, Filter: adım 1, 3 resimden 2. Shark Rotator Powered Lift-Away Speed Filter Replacement, Filter: adım 1, 3 resimden 3.
    • Press on the lift away button and pull away from the vacuum.
  2. Shark Rotator Powered Lift-Away Speed Filter Replacement: adım 2, 2 resimden 1. Shark Rotator Powered Lift-Away Speed Filter Replacement: adım 2, 2 resimden 2.
    • Press down on the hose release button and pull away from the vacuum.
  3. Shark Rotator Powered Lift-Away Speed Filter Replacement: adım 3, 3 resimden 1. Shark Rotator Powered Lift-Away Speed Filter Replacement: adım 3, 3 resimden 2. Shark Rotator Powered Lift-Away Speed Filter Replacement: adım 3, 3 resimden 3.
    • Pull the dust cup release latch and lift the dust cup from where it rests.
  4. Shark Rotator Powered Lift-Away Speed Filter Replacement: adım 4, 2 resimden 1. Shark Rotator Powered Lift-Away Speed Filter Replacement: adım 4, 2 resimden 2.
    • Pull out the foam filter from where the dust cup rested.
  5. Shark Rotator Powered Lift-Away Speed Filter Replacement: adım 5, 2 resimden 1. Shark Rotator Powered Lift-Away Speed Filter Replacement: adım 5, 2 resimden 2.
    • Pull out the felt filter from where the foam filter rested.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sujey Ruano
730 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S4-G6, White Fall 2018 Cal Poly, Team S4-G6, White Fall 2018 üyesi
CPSU-WHITE-F18S4G6
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 30
Her zaman: 3,297
