Ana içeriğe geç
Shark Rotator Powered Lift-Away Speed Headlight Replacement
Neye ihtiyacın var
  1. Shark Rotator Powered Lift-Away Speed Headlight Replacement, Headlight: adım 1, 2 resimden 1. Shark Rotator Powered Lift-Away Speed Headlight Replacement, Headlight: adım 1, 2 resimden 2.
    • Flip the vacuum on its underside, and use a coin to rotate the cam-screws on the bottom panel so that their grooves are parallel with the front of the vacuum.
  2. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 2, 2 resimden 1. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 2, 2 resimden 2.
    • Squeeze the sides of the roller brush cover release clasp, and swing the cover open.
  3. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 3, 1 resimden 1.
    • Using a T20 screwdriver remove five 15.9 mm screws on the outside of the cover.
  4. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 4, 2 resimden 1. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 4, 2 resimden 2.
    • Using a T20 screwdriver, remove three 13.4 mm screws from where the roller brush cover attaches to the bottom of the vacuum.
  5. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 5, 1 resimden 1.
    • Using a T20 screwdriver, remove two 13.4 mm screws from under the wheels.
  6. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 6, 1 resimden 1.
    • Using a T20 screwdriver, remove two 15.9 mm screws behind the vacuum wheels.
  7. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 7, 1 resimden 1.
    • Using a PH0 screwdriver bit, remove the single 13.4 mm screw in between the roller brush and where the release clasp was attached.
  8. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 8, 1 resimden 1.
    • Using a T20 screwdriver, remove the single 13.4 mm screw from behind the belted end of the roller brush.
  9. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 9, 3 resimden 1. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 9, 3 resimden 2. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 9, 3 resimden 3.
    • Flip the vacuum into the upright position, and use a spudger to open the front assembly cover by prying the seam where the colored front assembly and the grey side covers meet.
  10. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 10, 1 resimden 1.
    • Separate the front assembly cover from the vacuum.
  11. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 11, 3 resimden 1. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 11, 3 resimden 2. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 11, 3 resimden 3.
    • Use a spudger to remove the headlight covers by prying the seams where the headlight covers meet the bottom front of the vacuum.
  12. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 12, 3 resimden 1. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 12, 3 resimden 2. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 12, 3 resimden 3.
    • Pull the LED headlight strand up and away from where it is attached to the bottom front of the vacuum.
  13. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 13, 3 resimden 1. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 13, 3 resimden 2. Shark Rotator Powered Lift-Away Speed Headlight Replacement: adım 13, 3 resimden 3.
    • Pinch the tabs on the circuit board clasp for the LED headlight inwards , and pull the clasp up and away to detach the headlight.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Dakota Rodriguez-Ransom
605 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S4-G6, White Fall 2018 Cal Poly, Team S4-G6, White Fall 2018 üyesi
CPSU-WHITE-F18S4G6
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 20
Her zaman: 2,063
