Giriş
Are you experiencing a loss of suction? If so, an easy first step would be to check the vacuum's suction hose for any clogs, rips or separations, replace the suction hose assembly as necessary.
Neye ihtiyacın var
On the top portion of the suction hose, firmly press the tab.
Next, pull the suction hose up to detach it.
On the bottom portion of the suction hose, press the tab and pull the hose out.
2 farklı kişi bu kılavuzu tamamladı.
