Ana içeriğe geç
Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement
  1. Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement, HEPA Filter: adım 1, 2 resimden 1. Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement, HEPA Filter: adım 1, 2 resimden 2.
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement: adım 2, 2 resimden 1. Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement: adım 2, 2 resimden 2.
    • Remove the red cover from the front of the vacuum by pulling the latch found at the bottom of the cover forward and moving the whole cover downward.
  3. Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement: adım 3, 2 resimden 1. Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement: adım 3, 2 resimden 2.
    • Remove the filter by pulling it straight out.
    • To clean the filter, rinse it under water and allow it to dry before placing it back in the vacuum.
Sonuç
Carson Craft
251 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G3, White Winter 2019 Cal Poly, Team S19-G3, White Winter 2019 üyesi
CPSU-WHITE-W19S19G3
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 363
