Ana içeriğe geç
Shark Rotator Slim-Light Lift-Away Upright Motor Replacement
Neye ihtiyacın var
  1. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: adım 1, 2 resimden 1. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: adım 1, 2 resimden 2.
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: adım 2, 3 resimden 1. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: adım 2, 3 resimden 2. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: adım 2, 3 resimden 3.
    • Remove the two 19mm Phillips #2 screws located in the red plastic piece behind the filter.
  3. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: adım 3, 3 resimden 1. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: adım 3, 3 resimden 2. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: adım 3, 3 resimden 3.
    • Flip over vacuum and remove the six 12.7mm Phillips #2 screws from the base.
    • Take off white plastic cover exposing the motor in its insulation.
  4. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: adım 4, 3 resimden 1. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: adım 4, 3 resimden 2. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: adım 4, 3 resimden 3.
    • Remove the motor from the base and slide the insulation down along the wires.
    • Find the plastic caps on top of the black and white wires. Using pliers twist and carefully remove these caps.
    • Needle nosed pliers are recommended but not necessary.
    • These plastic caps are somewhat sensitive and can be difficult to take off. Additionally once taken off they can become unusable.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joshua Morrison
196 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G3, White Winter 2019 Cal Poly, Team S19-G3, White Winter 2019 üyesi
CPSU-WHITE-W19S19G3
5 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
What is the motor PN and where can I get one?
Dennis Meece - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 1,447
