Ana içeriğe geç
Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement
Neye ihtiyacın var
  1. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement, Roller Brush: adım 1, 2 resimden 1. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement, Roller Brush: adım 1, 2 resimden 2.
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: adım 2, 1 resimden 1.
    • Turn over the vacuum to reveal the roller brush.
  3. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: adım 3, 2 resimden 1. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: adım 3, 2 resimden 2.
    • Pry the small wheels at the bottom of the base using the plastic opening tool.
  4. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: adım 4, 2 resimden 1. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: adım 4, 2 resimden 2.
    • Using a coin, turn the big white knobs located above the roller brush counter-clockwise.
  5. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: adım 5, 3 resimden 1. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: adım 5, 3 resimden 2. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: adım 5, 3 resimden 3.
    • Lift up the suction hose to reveal a screw.
    • Remove the 12.7 mm Phillips #02 screw.
  6. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: adım 6, 2 resimden 1. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: adım 6, 2 resimden 2.
    • Remove eight 12.7mm screws located under the vacuum using a Phillips #02 screwdriver.
    • Remove two 12.7 mm screws located next to the wheels with a Phillips #02 screwdriver.
    • The two screws located next to the wheels are smaller in diameter.
  7. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: adım 7, 3 resimden 1. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: adım 7, 3 resimden 2. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: adım 7, 3 resimden 3.
    • Turn the vacuum upright and pull the white upper section of the brush roller circuit housing.
    • Be careful when lifting the housing as there is a connector attached.
  8. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: adım 8, 2 resimden 1. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: adım 8, 2 resimden 2.
    • Remove the connector attached to the circuit boards using a plastic opening tool.
  9. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: adım 9, 3 resimden 1. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: adım 9, 3 resimden 2. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: adım 9, 3 resimden 3.
    • Remove the two 12.7 mm screws located at the top of the clear plastic brush roller housing using a Phillips #02 screwdriver.
    • Lift the clear plastic brush roller housing.
  10. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: adım 10, 2 resimden 1. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: adım 10, 2 resimden 2.
    • Wiggle the brush roller upwards from the left and right side slots.
  11. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement, Roller Brush Belt: adım 11, 1 resimden 1.
    • Remove the roller brush by sliding it out toward the left, off the belt.
  12. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: adım 12, 1 resimden 1.
    • Remove the belt from the motor gear by sliding the belt away from the gear and belt motor.
    • In the following picture the belt was already removed.
Sonuç
Daniel Ceja
277 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G3, White Winter 2019 Cal Poly, Team S19-G3, White Winter 2019 üyesi
CPSU-WHITE-W19S19G3
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 557
