Ana içeriğe geç
Shark Steam Pocket Mop Power Cable Replacement
Neye ihtiyacın var
  1. Shark Steam Pocket Mop Power Cable Replacement, Back Panel: adım 1, 3 resimden 1. Shark Steam Pocket Mop Power Cable Replacement, Back Panel: adım 1, 3 resimden 2. Shark Steam Pocket Mop Power Cable Replacement, Back Panel: adım 1, 3 resimden 3.
    • Begin by removing the 8 quarter inch phillips head screws found along the back panel
    • Once all 8 screws have been removed, gently remove the back panel from the rest of the mop's body
  2. Shark Steam Pocket Mop Power Cable Replacement, Power Cable: adım 2, 2 resimden 1. Shark Steam Pocket Mop Power Cable Replacement, Power Cable: adım 2, 2 resimden 2.
    • Start by removing the two 1/8th inch Phillips head screws with your Phillips head screwdriver.
    • Gently remove the small plastic piece holding the wires against the plastic midframe of the mop.
    • Next use your wire cutters to remove the two plastic connectors and replace those wires with your new ones.
Sonuç
Jacob Howe
549 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G7, Cagle Fall 2017 USF Tampa, Team S13-G7, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S13G7
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 26
Her zaman: 1,671
