Ana içeriğe geç
Shark Steam Pocket Mop Steam Head Hose Replacement
Neye ihtiyacın var
  1. Shark Steam Pocket Mop Steam Head Hose Replacement, Steam Head Hose: adım 1, 3 resimden 1. Shark Steam Pocket Mop Steam Head Hose Replacement, Steam Head Hose: adım 1, 3 resimden 2. Shark Steam Pocket Mop Steam Head Hose Replacement, Steam Head Hose: adım 1, 3 resimden 3.
    • Start by removing this quarter inch Phillips head screw
    • Next remove the two 1/8th inch Phillips head screws at the bottom of the connector piece.
    • Next remove the nine 1/8th inch Phillips head screws along the base of the steam head connection.
    • Next remove the two 1/8th inch Phillips head screws along the base of the steam head connector.
  2. Shark Steam Pocket Mop Steam Head Hose Replacement: adım 2, 3 resimden 1. Shark Steam Pocket Mop Steam Head Hose Replacement: adım 2, 3 resimden 2. Shark Steam Pocket Mop Steam Head Hose Replacement: adım 2, 3 resimden 3.
    • Once all the screws are removed and the baseplate of the steam head connection has been placed aside, gently remove the connector from the bottom of the base.
    • Gently remove the end caps of the hinge piece of the connector piece with your fingers.
    • Gently remove the host connection from the back plate.
  3. Shark Steam Pocket Mop Steam Head Hose Replacement: adım 3, 2 resimden 1. Shark Steam Pocket Mop Steam Head Hose Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use your tweezers to remove the metal ring holding the hose to the plastic end piece and replace the hose / bit as needed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jacob Howe
549 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G7, Cagle Fall 2017 USF Tampa, Team S13-G7, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S13G7
4 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
Ok, but where do I get a replacement hose?
semajrolyat - Yanıt
Same question as semajrolyat: where to source replacement hose?
CLIFTON CHANG - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 1,942
